I created a rule with RM to beep when armed away or armed home and a door or window is opened. Question, how do i repeat the rule until the alarm is disarmed? Example?
I set this up ages ago and had forgotten all about it. I was using two rules but I see JBrown's suggestion is a much simpler approach, changing mine now.
Move the first action On:Buzzer to after the repeat while expression, that should fix it.
If you have an Iris/Centralite/Xfinity keypad, you can use the Nyckelharpa app.
I use Nyckelharpa with an Android tablet and it is excellent but I can only get it to chime once when delayed entry begins, rather than repeating every few seconds for the duration of delayed entry.
I am getting the desired trigger result but I can not stop the repeat. See attached. The beep should stop when All Disarmed.
I forgot "Stopable". Working correctly now.
