Here is a list of things that would be awesome to have:
Resize text on attribute template.
This is an example of an image template with an attribute template overlaid. I'd like to resize the attribute text so it fits within the window image I have.
remove the top value on all of the tiles.
I don't understand what the purpose of knowing it is a contact sensor provides.
Appreciate the idea. Noted as a feature request. Thanks! Can't say if or when it will be added, but we are actively gathering all the features we want to see in dashboard for future updates.
Patrick, encourage the team to contemplate a different grid layout system. Something with a masonry layout that would allow a flexible "Fit to window" grid with only an order required vs row x col.
I see this thread as containing feature requests for dashboards. So here are mine. I'm finally getting around to building some useful dashboards. I love the attribute option and button option, but can you add an additional text label field for those of us who don't / can't make pictures? To clarify; if I make a tile for a button controller and have it execute button press '1'. It displays as 'button 1', I'd like an alt label where I can enter what 'button 1' does. Thank you.
When adding a new tile, the grid is laid out top to bottom... i.e 1/1 is the top left, and let's say 3/6 is the bottom right... to get there I have to hit the 'up' button which is correct mathematically to change rows, but visually is opposite of 'down' which is visual contradictory. My pea brain might figure it out if they were +/-, but as shown with up/dn arrows. The left right arrows for column 'works' fine IMO.
Not quite a 'feature request', but sorta. might be related to @chrisUthe's post above if I technically understood it!
I'd rather get rid of the damnable arrows, no offense to the author, and see click and drag implemented. There are several good libraries to easily achieve it.
Better said than me! personally I don't care what it is if it's logical. Pushing an up arrow to go down makes the whisky flow...
Hang on... maybe that's not so bad afterall!!
I'd like to see a Master Template where any new dashboard or tile will automatically adopt the template. It's really a pain to get all tiles and all dashboards to have the same look. And an option to import that template into existing dashboards.
@patrick I think I have found a bug....
Whenever you try to change the template colours (icon) and you select a colour on the picker, as soon you click you are jumped back to the dasboard selection screen.
I have a white background and trying changing the text to black trigger this.
Creating a new dashboard, will try to replicate tomorrow with screen grab.
On Chrome for Android latest build.
How can I Access JavaScript console in android?
What is a difference between Standalone and WebUi? AFAIK there is only 1 Hubitat Dashboard App. This were the steps:
In Hubitat Dashboard App created a new Dasboard with a 3/4 Grid and a Background image.
in Dashboards selected the new Dashboard
After the New Dasboard I added a tile HSM Status/HSM
Than on the Dashboard top Right clicked the 3 dots and select template colours
Here I Select first HSM and than Disarmed for Example.
Than here you have 2 Boxes for colour (error happens in both) when you click on the field, a colour picker appears.
as soon you select a colour and drag the intensity bar down as soon it reaches the bottom or you release the selection your back on the Dashboard selection screen.
Well it does not refresh go back.
But it does not even allow to pick a colour. It allows to choose but when you click it should save it and go back and ends up doing nothing.
I potentially agree.. but Nowadays we do 80% plus of our online activity on mobiles not on pcs. In fact I rarely use my pc nowadays.
@patrick the most bizarre thing just happened I just updated to latest hot fix and most of my images on the dasboard are not loadinh, they are all valid and from the same website.
I had to reboot the hub for them to show up again. Just fyi
Edit: Reboot didn't solve the problems the images are not loading. Tried from 3 different devices e browsers.
I think I did not make my request clear. I would like to be able to change the default template (for instance, white icon, black background) and be able to make it global for all new dashboards. as well as being able to export that template to existing dashboards.
Would love to see a nicer looking dashboard too but for the sake of making it easier for others to help, is it possible to just expose CSS as an advanced feature? This way we can hide what we dont want, change sizes/colors/fonts of things etc... then people can share the CSS for those who don't know how to write it themselves.
For instance, I'd love to make the tiles have rounded corners, but i understand that as a feature, that's super-low on the priority list.. given access to CSS, i can do that in about a minute. (Currently looking at Maker API to make my own dashboard cause i find the included one so lacking, unfortunately).
