I've been reading around the forums but most stuff seems to be US focused.
I'm after a couple of plug-in energy monitors that I can move around the house and switch across various appliances, and then have the data feed back to Hubitat.
I've already got a couple of Innr "Smart sockets" which (in theory at least) should be able to send back power usage data, but I'm not seeing it show up in the UI,
I'm in the process of switching over the wall sockets to the Aurora AOne devices, but they're not cheap, and once they're installed they can't really be moved around (I've also got a few devices that are on "single sockets", and I can't see a single-socket version)
One thing I would mention is to be careful when using energy reporting. It is pretty easy to bog down your mesh and or hub with a flood of energy reporting devices. Energy reporting settings are typically in the device driver.
Yeah, I saw those, but my understanding is that they're for the consumer unit to monitor all the feeds in the house, rather than on an individual plug socket level?
With large appliances it can be difficult to find plugs that can handle the load without bursting into flames and burning your house down. I'd look for passing electrical certifications before considering one for a large appliance.
I had these and they all went in the bin - kept overheating and one got so bad it even damaged the wall outlet. Also one time one switched itself on for apparently no reason and had an expensive heater running in a room we rarely use for probably more than a day. Also their metering was up the creek, one of the plugs kept telling me it was running at 3kw several hours a day even when nothing was plugged in! Besides, aren't they cloud-dependent for almost everything but preset-schedule?
Wow, I can't say I've had any problems like that, the most I've had is they don't get back on the network that well when I restart the router. I don't run too much off them to be fair, the most intensive ones are probably the dishwasher and washing machine, but still haven't had any issues like you described.
I've had one of the TP-Link plugs start smoking and I unplugged it before it caught fire but it was close to ignition temp when I grabbed it. The plastic was squishy when I grabbed it. There was some scorch marks on the receptacle also. It's worth mentioning that I had a UPS that had a 85" QLED TV, Playstation, BluRay, and an AP plugged into it. That's why I prefer the clamp meters now. I do have the zooz power strip and it seems to be doing fine but I don't have much load on it. It's mostly just my network equipment.
I'm trying to avoid any of the home automation power management devices (sockets, switches, smart plugs etc) being on the WiFi if I can, I'll check out the Smarthings plugs.
Bit late, but I can recommend the Salus SP600. You need to use the community driver for power reporting at the moment, but it's officially supported and the reporting should be fixed. I'm writing my own driver for it as well, just for the heck of it (and for presence detection).
They crop up on eBay occasionally for reasonable prices. Got one for Β£15 and one for Β£10 recently, but they're always there for normal sale at Β£25-30 if you're in a rush.
Oh! You could also use the AlertMe SPG100 smart plugs if you can find them. The driver I did can read the usage in Wh as well as the current power in watts, they'll do the accrual and can be reset to zero without having to pair again (just hold the button on the top until they reboot). They're battery-backed repeaters too, though you'll likely need to change the rechargeables.
With this on my mind, the AlertMe Smart Plug driver (development version for the moment) supports the EnergyMeter capability properly now and reports usage in kWh.
Sorry, an old thread I know, but just thought I'd contribute as I always battle to find the best options around this and having a post with them all would be helpful.
The Samsung smartthings plug can also monitor power. I have one monitoring power from my pc. Unsure on any further integration though
