Has anyone worked on getting the Enbrighten Zwave bulbs working ?
The only way I got mine to work is using the generic Zwave dimmer device.
Yes , but same as you -- generic Zwave dimmer device
Crap -- missing out on the plus features also
What are the “plus features”?
Google Zwave Plus -- biggest difference is that its also a repeater.
The device its working on is just zwave.
I am pretty sure that the Device Driver does not have anything to do with whether or not the device acts as a z-wave repeater. Almost all mains-powered z-wave and z-wave plus device’s act as repeaters.
If you want to use Hubitat’s driver that is designed for z-wave plus devices, try the “Generic Z-Wave Smart Dimmer”.
Read more about these drivers here
Correct, driver plays no part in repeater functionality, nor does the hub for that matter.
Good to know
I have only been able to pair three of the 4 Enbrighten bulbs I have. The first one I paired isn't having any issues, but the the other two bulbs that paired won't turn on or off from Hubitat. I have removed them and repaired them several times to no avail. The bulb that is working works whether I use the "generic Zwave dimmer" or the "generic z-wave smart dimmer" driver.
I believe the smart dimmer supports the Zwave plus.
zwave smart dimmer is for devices that are capable of reporting state changes on their own, zwave dimmer is for devices that don't.
I stand corrected.......
