I've had a GE Enbrighten 46203 dimmer working for a few months now. Today, I tried adding a Zooz ZSE18 to the network. To test it, I created two rules: 1. trigger when motion active, turn switch on. 2. trigger when motion inactive, turn switch off. This seemed to work ok, except I could no longer control the lights from the wall paddles. Using hubitat to turn the light on and off worked. Using the wall paddles did not.
I deleted the two rules. Still can't control the dimmer from the wall paddles. Only from hubitat.
Tried to exclude it to repair it. Can't exclude it. I go to exclusion mode, and push the wall paddle but nothing happens. Try to force remove and get an Error 500. I've tried re-setting the hub.
Is the switch bricked or is there something else I can try here? Appreciate all thoughts.
