C8-Pro. Latest firmware.
I'm having an issue with my 3-way and 4-way light configurations, all using Enbrighten 700 Z-Wave switches, along with Enbrighten (or UltraPro) Add-on switches.
The problem I'm having is that most of the time (but not all of the time), the add-on switches will turn the lights on, but not off. At first I thought it might be a wiring issue, but I've checked (and re-checked) the wiring and it appears to be correct. (Also, given the simplicity of how the Enbrighten add-ons are meant to be wired, I don't believe that I could have messed up the wiring on all of them. I also replaced a couple of the Enbrighten master switches, but the new ones exhibit the same issue.)
Speaking of the master switches, they continue to operate perfectly, on or off (or dim in some cases), and the hub controls them perfectly. It's just the "dummy" add-on switches (that take only a neutral and a traveler) that often won't turn the lights off.
Now here's the strange thing ... when I first installed them (making sure that the wiring is correct), everything worked perfectly. Shortly thereafter, I noticed that one of the add-on switches would only turn the light on, but not off. I then discovered that all (but one) of my multi-way configurations were behaving the same way. BUT THEN, mysteriously, they all started functioning properly again later in the day. I've noticed that all of the add-ons fail at the same time, and they resume working at the same time ... but there seems to be no pattern (or timeframe) in which that happens. And as I said, during that time, the master Enbrighten 700 switches continue to work perfectly, and Hubitat controls them with no issues.
I called Jasco (Enbrighten/UltraPro) support, and they immediately said that it had to be a hub problem, but couldn't (or wouldn't) give me any more information than that. End-of-Conversation.
So, has anyone ever encountered this type of issue before, and if so ... could it be an issue in the hub (or perhaps a configuration issue)? (BTW, many of my other devices are Zooz 800 switches, I'm only using the Enbrighten switches for the 3-way and 4-way confifgurations.)
Any thoughts?
