Elevated and Severe Hub Loads with v2.3.4
I've not seen any of these load problems picked up in the Known Issues posts as yet, so I'm tagging it here in the hope it'll get some visibility.
@gopher.ny - you appear to be the official in the thread here! :slight_smile: Do you know if any of this is being investigated? I offered to provide any required info above, but heard nothing and the lockups were causing "domestic issues", so I had to revert to the previous version.
My hubs are all back to loads around 0.1 - 0.3 or below now I've reverted to 2.3.3.140. I do use Hub Mesh and run with the Z-Wave radio disabled.
@gopher.ny well my C3 hub has been running fine for a day and a half on firmware 2.3.4.119 and no lock ups.
I disabled zigbee and put the Zwave stick back in (Zwave still disabled in settings)
thanks for the help.
I've been getting this elevated and severe load messages on and off over the past few weeks but under device and app stats, nothing stands out as extreme.
For about the same time I thought I was losing my mind with certain automation getting missed, lights not turning on or off, etc. Typically I'll reboot the hub and all seems fine again.
What are you guys using to display database size, memory, etc on the dashboard?
I was using "hub info driver" but it was constantly at the top of my devices list so I nixxed it thinking it was a problem.
Probably what most people are using. If you’re seeing an issue with it, deleting and reinstalling the code before using it again may clear that up. So many people are using it that if there was a bug, it probably would have been reported and fixed. If your issue (elevated or severe load) is persistent, you should probably see if @gopher.ny can take a look at your hub.
Right, please PM me the hub id if you want me to check the engineering logs on it. Most of the time it has some clues to what's going on.
Just a note I went back to 2.3.3.140 after loading 2.3.4.120 and 2.3.4.122. I had issues with my Shelly's and IP Web Queries to my IP devices. Everything seem to slow down or misfire and on 2.3.4 I had a complete timeout for the web gui. Had to hard reset the box. Didn't have time to troubleshoot, wife got mad.
So what's the consensus here? I see a bunch of threads on this but no apparent solution after scrolling through many pages.
Should I just wait for (a hopefully soon) update that fixes this?
Best to raise a support request or remind the developers about it on here. I’ve had to revert to 2.3.3.140 and can’t upgrade until whatever it is has been resolved, but I’ve not seen anything related in the release notes.
Clearly there’s a bug with some particular configurations, but who knows what we have in common, or even if it’s as straightforward as that. When I get a little time I’ll post a bit more about my setup (which is back to behaving perfectly on 2.3.3).
If someone has similar issues on latest firmware (2.3.4.127 as of time of writing), please post here or PM me. I've done some internal tweaks and would like to confirm whether the issue still persists.
Thanks for looking in to this, I would try updating one of the hubs and testing this, but I'm not able to do so at the moment. Should be okay to try in a couple of weeks if nobody else has given it a whirl.
I’m not getting elevated loads, however my primary hub is still dropping below 250k memory free after only about 24 hours.
If I let it get below 220k, all rules etc start failing to run on time etc.
Mine still dop down to below 200 and everything runs ok..so it is not just a memory issue.
Im running into severe load also with no real changes to my setup. Is a fix on the way.
I dowgraded mine to 2.3.3.140 which solved the overload issue but now having this problem again Predicate condition is true but system think's it's false - #19 by makirules
Sighhh
Urgh, is this hub overload problem still a thing for people?
Not seeing it being reported, but YMMV.
Can you PM me the hub id? I can take a look at the engineering logs on the hub. No need to bump it back 2.3.4, if there's something in the logs it would be there from previous runs.
Sorry @gopher.ny and @birdslikewires
I had previously rolled back because of the severe load problem. Last night I updated to 2.3.4.133 and don't have any overload errors yet. I'm hoping it doesn't resurface but if it does, I'll report back.
As far as the other issue goes, I think I better make a new thread since it's completely unrelated.
I haven’t seen severe loads since upgrading to .133
My C7 with 2.3.4.133 locked up last night. I rebooted normally, and it seemed OK after that.
Today I came up to an unresponsive hub. I needed to use SafeMode to reboot. Logs indicate it was frozen for 2 hours. Within 5 minutes I got the Severe overload warning. Nothing in the logs - either before or after the reboot - really stands out as any culprit to cause the lockup.
I just reverted to 2.3.3.140 and will follow this thread.
