I did port it but I only have an energy value, which increments over time.
* Aeon Labs Smart Switch (2nd Edition) - DSC24
* Copyright 2015 Elastic Development
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Revision History
* 2015-01-24: Version: 1.0.0
* Initial Revision
* Developer's Notes
* Raw Description 0 0 0x1001 0 0 0 c 0x25 0x32 0x27 0x2C 0x2B 0x70 0x85 0x56 0x72 0x86 0xEF 0x82
* Z-Wave Supported Command Classes:
* Code Name Version
* 0x25 COMMAND_CLASS_SWITCH_BINARY V1
* 0x32 COMMAND_CLASS_METER V3
* 0x70 COMMAND_CLASS_CONFIGURATION V1
* 0x56 COMMAND_CLASS_CRC_16_ENCAP V1
* ---- --- Supported but unimplemented --- --
* 0x85 COMMAND_CLASS_ASSOCIATION V2
* 0x27 COMMAND_CLASS_SWITCH_ALL V1
* 0x2C COMMAND_CLASS_SCENE_ACTUATOR_CONF V1
* 0x2B COMMAND_CLASS_SCENE_ACTIVATION V1
* 0x72 COMMAND_CLASS_MANUFACTURER_SPECIFIC V2
* 0x86 COMMAND_CLASS_VERSION V1
* 0xEF COMMAND_CLASS_MARK V1
* 0x82 COMMAND_CLASS_HAIL V1
metadata {
definition (name: "Aeon Labs Smart Switch (2nd Edition)", namespace: "elasticdev", author: "James P") {
capability "Switch"
capability "Energy Meter"
capability "Actuator"
capability "Power Meter"
capability "Configuration"
capability "Polling"
capability "Refresh"
attribute "voltage", "number"
attribute "current", "number"
command "reset"
command "locate"
fingerprint deviceId: "0x1001", inClusters: "0x25, 0x32, 0x27, 0x2C, 0x2B, 0x70, 0x85, 0x56, 0x72, 0x86, 0xEF, 0x82"
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
for (int i = 0; i <= 100; i += 10) {
status "energy ${i} kWh": new hubitat.zwave.Zwave().meterV2.meterReport(
scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
valueTile("energy", "device.energy", decoration: "flat") {
state "default", label:'${currentValue} kWh'
standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat") {
state "default", label:'reset kWh', action:"reset", icon:"st.secondary.refresh-icon"
valueTile("power", "device.power", decoration: "flat") {
state "default", label: '${currentValue} W'
valueTile("current", "device.current", decoration: "flat") {
state "default", label: '${currentValue} A'
valueTile("voltage", "device.voltage", decoration: "flat") {
state "default", label: '${currentValue} V'
standardTile("configure", "device.power", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("locate", "device.power", inactiveLabel: false, decoration: "flat") {
state "default", label:'locate', action:"locate", icon:"st.presence.tile.presence-default"
main (["switch","energy","power","current"])
details(["switch","energy","reset","power","current", "voltage","configure","refresh", "locate"])
preferences {
input "disableOnOff", "boolean",
title: "Disable On/Off?",
defaultValue: false,
displayDuringSetup: true
input "reportInterval", "number",
title: "Report Interval",
description: "The time interval in minutes for sending device reports",
defaultValue: 1,
required: false,
input "switchAll", "enum",
title: "Respond to switch all?",
description: "How does the switch respond to the 'Switch All' command",
options:["Disabled", "Off Enabled", "On Enabled", "On And Off Enabled"],
defaultValue: "On And Off Enabled",
required:false,
input "debugOutput", "boolean",
title: "Enable debug logging?",
* Methods *
* updated - Called when the preferences of the device type are changed
def updated() {
state.onOffDisabled = ("true" == disableOnOff)
state.debug = ("true" == debugOutput)
if (state.onOffDisabled) log.debug "updated(disableOnOff: ${disableOnOff}(${state.onOffDisabled}), reportInterval: ${reportInterval}, switchAll: ${switchAll}, debugOutput: ${debugOutput}(${state.debug}))"
response(configure())
* parse - Called when messages from a device are received from the hub
* The parse method is responsible for interpreting those messages and returning Event definitions.
* String description The message from the device
if (state.onOffDisabled) log.debug "Parse(description: \"${description}\")"
def event = null
// The first parameter is the description string
// The second parameter is a map that specifies the version of each command to use
def cmd = zwave.parse(description, [0x20: 1, 0x25: 1, 0x32 : 3, 0x56 : 1, 0x70 : 1, 0x27 : 1, 0x2B : 1, 0x2C : 1, 0x72 : 2, 0x82 : 1, 0x85 : 2 ,0x86 : 1, 0xEF : 1])
if (cmd) {
event = createEvent(zwaveEvent(cmd))
if (state.onOffDisabled) log.debug "Parse returned ${event?.inspect()}"
return event
* on - Turns on the switch
* Required for the "Switch" capability
def on() {
if (state.onOffDisabled) {
if (state.debug) log.debug "On/Off disabled"
delayBetween([
zwave.basicV1.basicGet().format(),
zwave.switchBinaryV1.switchBinaryGet().format()
else {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
* off - Turns off the switch
def off() {
delayBetween([
else {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
* poll - Polls the device
* Required for the "Polling" capability
def poll() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.meterV3.meterGet(scale: 0).format(), //kWh
zwave.meterV3.meterGet(scale: 2).format(), //Wattage
zwave.meterV3.meterGet(scale: 4).format(), //Voltage
zwave.meterV3.meterGet(scale: 5).format() //Current
* refresh - Refreshed values from the device
* Required for the "Refresh" capability
def refresh() {
delayBetween([
* reset - Resets the devices energy usage meter
* Defined by the custom command "reset"
def reset() {
return [
zwave.meterV3.meterReset().format(),
zwave.meterV3.meterGet(scale: 0).format() //kWh
* locate - locates the device by cycling the switch for some period of time
* Defined by the custom command "locate"
def locate() {
delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: 0xFC, size: 1, scaledConfigurationValue: 0).format(), //Disable Lock Configuration (0 =disable, 1 = enable).
zwave.configurationV1.configurationSet(parameterNumber: 0x02, size: 2, scaledConfigurationValue: 0x0F0A).format(), //cycle on/off every second for 15 seconds
zwave.configurationV1.configurationSet(parameterNumber: 0xFC, size: 1, scaledConfigurationValue: 1).format() //Enable Lock Configuration (0 =disable, 1 = enable).
* configure - Configures the parameters of the device
* Required for the "Configuration" capability
def configure() {
//Get the values from the preferences section
def reportIntervalSecs = 60;
if (reportInterval) {
reportIntervalSecs = 60 * reportInterval.toInteger()
def switchAllMode = hubitat.zwave.commands.switchallv1.SwitchAllSet.MODE_INCLUDED_IN_THE_ALL_ON_ALL_OFF_FUNCTIONALITY
if ("Disabled" == switchAll) {
switchAllMode = hubitat.zwave.commands.switchallv1.SwitchAllSet.MODE_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY
else if ("Off Enabled" == switchAll) {
switchAllMode = hubitat.zwave.commands.switchallv1.SwitchAllSet.MODE_EXCLUDED_FROM_THE_ALL_ON_FUNCTIONALITY_BUT_NOT_ALL_OFF
else if ("On Enabled" == switchAll) {
switchAllMode = hubitat.zwave.commands.switchallv1.SwitchAllSet.MODE_EXCLUDED_FROM_THE_ALL_OFF_FUNCTIONALITY_BUT_NOT_ALL_ON
Device specific configuration parameters
Param Size Default Description
0x02 2 0x0F0A Make Smart Switch blink.
0x03 1 0 Current Overload Protection (0=disabled, 1=enabled)
0x50 1 0 Enable to send notifications to associated devices in Group 1 when load changes (0=nothing, 1=hail CC, 2=basic CC report)
0x5A 1 0 Enables/disables parameter 0x5B and 0x5C (0=disabled, 1=enabled)
0x5B 2 50 The value here represents minimum change in wattage for a REPORT to be sent (Valid values 0‐ 60000)
0x5C 1 10 Enables/disables parameter 0x5B and 0x5C (0=disabled, 1=enabled)
0x64 1 N/A Set 0x65-0x67 to default
0x65 4 4 Which reports need to send in Report group 1
0x66 4 8 Which reports need to send in Report group 2
0x67 4 0 Which reports need to send in Report group 3
0x6E 1 N/A Set 0x6F-0x71 to default.
0x6F 4 3 The time interval in seconds for sending Report group 1 (Valid values 0x01‐0x7FFFFFFF).
0x70 4 600 The time interval in seconds for sending Report group 2 (Valid values 0x01‐0x7FFFFFFF).
0x71 4 600 The time interval in seconds for sending Report group 3 (Valid values 0x01‐0x7FFFFFFF).
0xC8 1 0 Partner ID (0= Aeon Labs Standard Product, 1= Others).
0xFC 1 0 Enable/Disable Lock Configuration (0 =disable, 1 = enable).
0xFE 2 0 Device Tag
0xFF 1 N/A Reset to factory default setting
Configuration Values for parameter 0x02:
MSB 1-255 Specifies the time that Smart Switch blinks, The unit is Second;
LSB 1-255 Specifies the on/off status of the cycle, its unit is 0.1 second.
Example - Sending the value of 0x0F0A
Smart Switch will cycle on/off every second (0x0A = 10) and repeat for 15 seconds (0x0F = 15)
Configuration Values for parameters 0x65-0x67:
BYTE | 7 6 5 4 3 2 1 0
MSB 0 | 0 0 0 0 0 0 0 0
Val 1 | 0 0 0 0 0 0 0 0
VAL 2 | 0 0 0 0 0 0 0 0
LSB 3 | 0 0 0 0 A B C D
Bit A - Auto send Meter REPORT (for kWh) at the group time interval
Bit B - Auto send Meter REPORT (for watt) at the group time interval
Bit C - Auto send Meter REPORT (for current) at the group time interval
Bit D - Auto send Meter REPORT (for voltage) at the group time interval
Example - Send meter report for watt and voltage at group time interval
value is 0x0005
Example - Send meter report for kWh and current at group time interval
value is 0x000A or 10 (decimal)
Example - Send meter report for all values at group time interval
value is 0x000F or 15 (decimal)
if (state.debug) log.debug "configure(reportIntervalSecs: ${reportIntervalSecs}, switchAllMode: ${switchAllMode})"
delayBetween([
zwave.switchAllV1.switchAllSet(mode: switchAllMode).format(),
zwave.configurationV1.configurationSet(parameterNumber: 0x50, size: 1, scaledConfigurationValue: 2).format(), //Enable to send notifications to associated devices when load changes (0=nothing, 1=hail CC, 2=basic CC report)
zwave.configurationV1.configurationSet(parameterNumber: 0x5A, size: 1, scaledConfigurationValue: 1).format(), //Enables parameter 0x5B and 0x5C (0=disabled, 1=enabled)
zwave.configurationV1.configurationSet(parameterNumber: 0x5B, size: 2, scaledConfigurationValue: 50).format(), //Minimum change in wattage for a REPORT to be sent (Valid values 0‐ 60000)
zwave.configurationV1.configurationSet(parameterNumber: 0x5C, size: 1, scaledConfigurationValue: 10).format(), //Minimum change in percentage for a REPORT to be sent (Valid values 0‐ 100)
zwave.configurationV1.configurationSet(parameterNumber: 0x65, size: 4, scaledConfigurationValue: 15).format(), //Which reports need to send in Report group 1
zwave.configurationV1.configurationSet(parameterNumber: 0x6F, size: 4, scaledConfigurationValue: reportIntervalSecs).format(), //Send Report to group 1 for this interval (Valid values 0x01‐0x7FFFFFFF).
* Event Handlers *
* Default event handler - Called for all unhandled events
def zwaveEvent(hubitat.zwave.Command cmd) {
if (state.debug) {
log.debug "Unhandled: $cmd"
createEvent(descriptionText: "${device.displayName}: ${cmd}")
else {
* COMMAND_CLASS_CRC_16_ENCAP (0x56)
* List<Short> commandByte
* Short commandClassIdentifier
* Short commandIdentifier
* List<Short> initializationVector
* List<Short> messageAuthenticationCode
* Short receiversNonceIdentifier
* Boolean secondFrame
* Short sequenceCounter
* Boolean sequenced
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
// Devices that support the Security command class can send messages in an encrypted form
// they arrive wrapped in a SecurityMessageEncapsulation command and must be unencapsulated
// Like zwave.parse, the parameter is a map that can specify command class versions here like in zwave.parse
def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x25: 1, 0x32 : 3, 0x56 : 1, 0x70 : 1, 0x27 : 1, 0x2B : 1, 0x2C : 1, 0x72 : 2, 0x82 : 1, 0x85 : 2 ,0x86 : 1, 0xEF : 1])
if (encapsulatedCommand) {
return zwaveEvent(encapsulatedCommand)
* COMMAND_CLASS_BASIC (0x20)
* Short value 0xFF for on, 0x00 for off
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd)
if (state.debug) log.debug "BasicSet(value:${cmd.value})"
createEvent(name: "switch", value: cmd.value ? "on" : "off", type: "physical", displayed: true, isStateChange: true)
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd)
if (state.debug) log.debug "BasicReport(value:${cmd.value})"
createEvent(name: "switch", value: cmd.value ? "on" : "off", type: "physical")
* COMMAND_CLASS_SWITCH_BINARY (0x25)
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinarySet cmd)
if (state.debug) log.debug "SwitchBinarySet(value:${cmd.value})"
createEvent(name: "switch", value: cmd.value ? "on" : "off", type: "digital", displayed: true, isStateChange: true)
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
if (state.debug) log.debug "SwitchBinaryReport(value:${cmd.value})"
createEvent(name: "switch", value: cmd.value ? "on" : "off", type: "digital")
* COMMAND_CLASS_METER (0x32)
* Integer deltaTime Time in seconds since last report
* Short meterType Unknown = 0, Electric = 1, Gas = 2, Water = 3
* List<Short> meterValue Meter value as an array of bytes
* Double scaledMeterValue Meter value as a double
* List<Short> previousMeterValue Previous meter value as an array of bytes
* Double scaledPreviousMeterValue Previous meter value as a double
* Short size The size of the array for the meterValue and previousMeterValue
* Short scale The scale of the values: "kWh"=0, "kVAh"=1, "Watts"=2, "pulses"=3, "Volts"=4, "Amps"=5, "Power Factor"=6, "Unknown"=7
* Short precision The decimal precision of the values
* Short rateType ???
* Boolean scale2 ???
def zwaveEvent(hubitat.zwave.commands.meterv3.MeterReport cmd) {
def meterTypes = ["Unknown", "Electric", "Gas", "Water"]
def electricNames = ["energy", "energy", "power", "count", "voltage", "current", "powerFactor", "unknown"]
def electricUnits = ["kWh", "kVAh", "W", "pulses", "V", "A", "Power Factor", ""]
if (state.debug) log.debug "MeterReport(deltaTime:${cmd.deltaTime} secs, meterType:${meterTypes[cmd.meterType]}, meterValue:${cmd.scaledMeterValue}, previousMeterValue:${cmd.scaledPreviousMeterValue}, scale:${electricNames[cmd.scale]}(${cmd.scale}), precision:${cmd.precision}, rateType:${cmd.rateType})"
//NOTE ScaledPreviousMeterValue does not always contain a value
def previousValue = cmd.scaledPreviousMeterValue ?: 0
def map = [ name: electricNames[cmd.scale], unit: electricUnits[cmd.scale], displayed: false]
switch(cmd.scale) {
case 0: //kWh
previousValue = device.currentValue("energy") ?: cmd.scaledPreviousMeterValue ?: 0
map.value = cmd.scaledMeterValue
break;
case 1: //kVAh
break;
case 2: //Watts
previousValue = device.currentValue("power") ?: cmd.scaledPreviousMeterValue ?: 0
map.value = Math.round(cmd.scaledMeterValue)
break;
case 3: //pulses
break;
case 4: //Volts
previousValue = device.currentValue("voltage") ?: cmd.scaledPreviousMeterValue ?: 0
break;
case 5: //Amps
previousValue = device.currentValue("current") ?: cmd.scaledPreviousMeterValue ?: 0
break;
case 6: //Power Factor
case 7: //Unknown
break;
default:
break;
//Check if the value has changed my more than 5%, if so mark as a stateChange
map.isStateChange = ((cmd.scaledMeterValue - previousValue).abs() > (cmd.scaledMeterValue * 0.05))
createEvent(map)
//EOF
