Requires newest firmware, the fact that you cannot see it means my setup is working! Here is what I got form Zooz below. Hope they don't mind me posting this, it looks like a copy of what they plan to add to their docs. They asked me to add these settings so they better know its going to generate questions
. Oh and don't ask what the association groups are for, with them adding group 4, I don't know which does what, I am waiting for more info.
New parameter info from Zooz
Below are the new settings which have been added to the following dimmer versions so far:
ZEN72 10.10 (ver. 1.0 hardware) and 2.0 (ver. 2.0 hardware)
ZEN74 10.10 (ver. 1.0 hardware, no 2.0 hardware available at the moment)
ZEN77 10.20 (ver. 1.0 hardware), 2.10 (ver. 2.0 hardware), and 3.0 (ver. 3.0 hardware)
Remote Z-Wave Dimming Duration (Multilevel Commands For Group 3 And 4)
Parameter 30: Set the time it takes to get from 0% to 100% brightness on dimmers and smart bulbs directly associated with your dimmer in Groups 3 and 4 when pressing and holding the paddle (physical dimming) on your dimmer. The number entered as value corresponds to the number of seconds.
Values: 1 β 99 (seconds). Default: 5.
Size: 1 byte dec
Ramp Rate Control
Parameter 9: Adjust the ramp rate ON for your dimmer when the top paddle is pressed (physical ramp rate on). Values correspond to the number of seconds it take for the dimmer to reach full brightness when operated manually.
Values: 1 β 99 (seconds). 0 β instant on. Default: 0.
Size: 1 byte dec
NOTE: On all other previous firmware versions including 1.0 and 10.0, this setting was used for all ramp rate control (to adjust behavior for on/off physical and Z-Wave ramp rate). The default value for this parameter used to be 1.
Parameter 27: Adjust the ramp rate OFF for your dimmer when the bottom paddle is pressed (physical ramp rate off). Values correspond to the number of seconds it take for the dimmer to turn off when operated manually.
Values: 1 β 99 (seconds). 0 β instant off. Default: 2.
Size: 1 byte dec
Parameter 28: Adjust the ramp rate ON for your dimmer when a Z-Wave command is sent to turn the dimmer on (Z-Wave ramp rate on). Values correspond to the number of seconds it take for the dimmer to reach full brightness when operated via Z-Wave.
Values: 1 β 99 (seconds). 0 β instant on. 255 β match physical. Default: 255.
Size: 1 byte dec
Parameter 29: Adjust the ramp rate OFF for your dimmer when a Z-Wave command is sent to turn the dimmer off (Z-Wave ramp rate off). Values correspond to the number of seconds it take for the dimmer to turn off when operated via Z-Wave.
Values: 1 β 99 (seconds). 0 β instant off. 255 β match physical. Default: 255.
Size: 1 byte dec
