[DRIVER] Zooz ZEN Switches Advanced (and Dimmers)
I think this is due to a breaking change with the new UI...
You can insert one line of code in that function which should fix it for now. I really need to get some updates pushed out. My process is slow unfortunately.
Anyway, add this line at the top of the function so it looks like this when done:
String setParameter(paramNum, value, size = null) {
	paramNum = safeToInt(paramNum)
	Map param = getParam(paramNum)
Problem is that it used to come across as an integer already but now it is coming in as a BigDecimal so I have to convert it so it works in the next function being called (line 676).
