Yeah it should work for any plug. Due to the large number of different brands and requests from people I built it in a way so it doubles as a generic driver for any smart plug with or without power metering. It would even work for any multi-channel non-metering device. You will get a warning that it is an unknown device but just ignore that.
I really need to hunker down and get some stuff cranked out. Adding a plug driver was next on my todo list for the Universal set.
Yeah I reviewed these a while back. They are the same as some drivers you can find on GitHub so not sure if they were commissioned by Minoston or they just borrowed them from github to slap on their web site. They looked like a messy port from old ST code, I was not impressed.
Ha, yes, a hacky port of an older ST stuff is exactly what I suspected too... It's obvious that effort was put into those builds at some point, but equally obvious it wasn't specifically designed for Hubitat, so it being older code from ST made the most sense to me.
Thanks for confirming I'm (probably) not going crazy.
I changed to this driver (Zooz Xen Plugs Advanced) and was unable to control the plug - both automations and control from Device page failed for some reason.
Change driver/save.
Configure, Refresh, sync status showed syncing and then completed
Ran my normal RL automation that uses this plug, plug didn't come on
Turned on from Device page, plug didn't turn on
Reverted to EvaLogik driver, and plug works normally again from RL and from Device page
I've never tried Jeff's driver with my Minostons -- IIRC, I knew they'd come in as an unknown device, so I just decided to go straight to using the Basic ZW Tool and the Generic Outlet driver.
Oh I just realized that MP21ZD is a dimmer module, this plug driver is for on/off plugs not dimmers.
I have a Leviton dimmer plug driver but I don't think it would gain you anything over the system one.
Or you could also try my Universal Dimmer driver. Also the Universal Switch driver should work for non-metering on/off plugs and may be able to give you all the settings exposed.
Just assigned this driver. Lights are being controlled normally, no issues so far. I did get a couple error logs during setup (believe related to the plug not being configured w/S2. Posted details in the appropriate topic.
I recently installed two new ZEN15 switches with firmware 2.10 and am using Zooz ZEN Plugs Advanced 1.2.6. Neither switch shows Energy or Power data (always 0). Sync Status always shows "1 Pending Changes" despite pressing Configure many times. Is there something else I need to be setting to get this working right? Thanks.
What does your preferences settings look like? Maybe you have it configured to only report once a day, and so it took a while. Don't know about the pending change, though.
Not sure how the overload protection is trying to set to 1, you should have a dropdown in the settings to pick from 2-5 seconds, change it to something else and save, then change it back 2 if you want the default.
FWIW, I don't think I've ever messed with the Preferences. There is something weird in 'Overload Protection' where it's showing some HTML code in the dropdown box. In that section, it showed "Parameter #20, Selected: 1". When I do select the dropdown arrow, it shows the seconds choices. I changed it to 3 then 2 which display properly now. Doesn't look like "1" should have been an option.
I also see now that Power (Watts) Reporting Frequency is set to 0 when the default is 10. I didn't make that selection. Same issue with Energy (kWh) Reporting Frequency, These ZEN15s were brand new in the box. Same issues for both of them.
OK, the ZEN15 where I made the Overload Protection change is now showing as Synced. They're both reporting Power and Energy even though those settings are still set to 0.
They'll always show all that information in the Current States section, but they'll only report (log as event) what you define in parameters.
Any power-reporting device can cobble its mesh network pretty hard & fast if the reporting parameters are left too wide, so you're encouraged to prune those parameters to just what you need for that particular monitoring situation.
The settings issues are probably residual leftovers from originally pairing them on the system driver, before the custom was installed. System driver is probably setup for the old 1.06 ZEN15 which had different settings options. My driver is dynamic based on the firmware.
If you want to disable some of the reporting use the Reset command to clear out the old values. I think that clears everything anyway...
Request for a new feature in Zooz ZEN Plugs MCP Advanced: Ability to keep the outlet from ever turning off..ignore zwave off commands and/or physical button. I have a ZEN20 where a couple of the outlets are running something I dont ever want off.
Just wanting to make sure knew that you can already disable local control. I didn't see a parameter for disabling digital control, but if you don't use the device in any rules or apps other than energy monitoring, is that likely?
FWIW, I have many ZEN15 on things that should never be off. I turned off local control, and I have a rule that turns it on every five minutes.
