Ok sorry can you try/do one more thing. Install and switch to this driver: [RELEASE] Z-Wave Universal Device Scanner
Set the logging to debug logging.
Sounds like it sends a notification when you plug it in, so unplug and the re-plug it. Should get some debug logs from the alert.
Also try the test button. It is possible the device does not alert the hub when a test is done.
In the meantime I can look into the zwave space and start preparing a driver to handle it assuming this device follows current specs.
UPDATE: I looked up the spec and got that coded into a driver based on a smoke/co one I worked on, but it sounds like this device plugs in? My other sensor drivers are for battery devices so I need to do a little more adjusting to handle a plugged in device.
