Hey there,
here we go with another attempt to integrate Ikea stuff.
So I was playing around with the driver from @birdslikewires for the Symfonisk sound controllers, and I've noticed, that I can get a readout for the Ikea Dimmer Switch.
This one: TRÅDFRI Kabelloser Dimmer, weiß - IKEA Deutschland
I've tried to modify it a little and managed to get a correct battery readout and presence status.
This is, what I got so far:
* Ikea TRADFRI onoff switch Driver v1 (23th November 2021)
import groovy.transform.Field
metadata {
definition (name: "Ikea TRADFRI onoff switch", namespace: "Vincent", author: "Andrew Davison") {
capability "Battery"
capability "Configuration"
capability "DoubleTapableButton"
capability "HoldableButton"
capability "Initialize"
capability "Momentary"
capability "PresenceSensor"
capability "PushableButton"
capability "Refresh"
capability "ReleasableButton"
capability "Switch"
capability "SwitchLevel"
attribute "batteryState", "string"
attribute "batteryWithUnit", "string"
attribute "direction", "string"
attribute "levelChange", "integer"
//command "checkPresence"
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,0020,1000,FC7C", outClusters: "0003,0004,0006,0008,0019,0102,1000", manufacturer: "IKEA of Sweden", model: "TRADFRI onoff switch", deviceJoinName: "TRADFRI onoff switch", application: "21"
@Field int reportIntervalSeconds = 3600 // How often should the device report in.
@Field int presenceTimeoutMinutes = 140 // Allow one missed report with some leeway.
preferences {
input name: "infoLogging", type: "bool", title: "Enable logging", defaultValue: true
input name: "debugLogging", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "traceLogging", type: "bool", title: "Enable trace logging", defaultValue: true
def installed() {
// Runs after first pairing.
logging("${device} : Paired!", "info")
def initialize() {
// Set states to starting values and schedule a single refresh.
// Runs on reboot, or can be triggered manually.
// Reset states.
state.clear()
state.presenceUpdated = 0
sendEvent(name: "presence", value: "present", isStateChange: false)
// Initialisation complete.
logging("${device} : Initialised", "info")
def configure() {
// Set preferences and ongoing scheduled tasks.
// Runs after installed() when a device is paired or rejoined, or can be triggered manually.
initialize()
unschedule()
// Default logging preferences.
device.updateSetting("infoLogging",[value:"true",type:"bool"])
device.updateSetting("debugLogging",[value:"true",type:"bool"])
device.updateSetting("traceLogging",[value:"true",type:"bool"])
// Important Bit
sendZigbeeCommands(zigbee.onOffConfig())
sendZigbeeCommands(zigbee.configureReporting(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0021, DataType.UINT8, reportIntervalSeconds, reportIntervalSeconds, 0x00)) // Report in regardless of other changes.
sendZigbeeCommands(zigbee.enrollResponse())
// Schedule the presence check.
int checkEveryMinutes = 10 // Check presence timestamp every 10 minutes.
randomSixty = Math.abs(new Random().nextInt() % 60)
schedule("${randomSixty} 0/${checkEveryMinutes} * * * ? *", checkPresence) // At X seconds past the minute, every checkEveryMinutes minutes.
// Configuration complete.
logging("${device} : Configured", "info")
def updated() {
// Runs whenever preferences are saved.
loggingStatus()
runIn(3600,infoLogOff)
runIn(2400,debugLogOff)
runIn(1200,traceLogOff)
refresh()
void loggingStatus() {
log.info "${device} : Logging : ${infoLogging == true}"
log.debug "${device} : Debug Logging : ${debugLogging == true}"
log.trace "${device} : Trace Logging : ${traceLogging == true}"
void traceLogOff(){
log.trace "${device} : Trace Logging : Automatically Disabled"
device.updateSetting("traceLogging",[value:"false",type:"bool"])
void debugLogOff(){
log.debug "${device} : Debug Logging : Automatically Disabled"
device.updateSetting("debugLogging",[value:"false",type:"bool"])
void infoLogOff(){
log.info "${device} : Info Logging : Automatically Disabled"
device.updateSetting("infoLogging",[value:"false",type:"bool"])
void reportToDev(map) {
String[] receivedData = map.data
def receivedDataCount = ""
if (receivedData != null) {
receivedDataCount = "${receivedData.length} bits of "
logging("${device} : UNKNOWN DATA! Please report these messages to the developer.", "warn")
logging("${device} : Received : cluster: ${map.cluster}, clusterId: ${map.clusterId}, attrId: ${map.attrId}, command: ${map.command} with value: ${map.value} and ${receivedDataCount}data: ${receivedData}", "warn")
logging("${device} : Splurge! : ${map}", "trace")
void off() {
sendEvent(name: "switch", value: "off")
sendEvent(name: "pushed", value: 1, isStateChange: true)
logging("${device} : Switch : Off", "info")
void on() {
sendEvent(name: "switch", value: "on")
logging("${device} : Switch : On", "info")
void push(buttonId) {
sendEvent(name:"pushed", value: buttonId, isStateChange:true)
void doubleTap(buttonId) {
sendEvent(name:"doubleTapped", value: buttonId, isStateChange:true)
void hold(buttonId) {
sendEvent(name:"held", value: buttonId, isStateChange:true)
void release(buttonId) {
sendEvent(name:"released", value: buttonId, isStateChange:true)
void setLevel(BigDecimal level) {
setLevel(level,1)
void setLevel(BigDecimal level, BigDecimal duration) {
BigDecimal safeLevel = level <= 100 ? level : 100
safeLevel = safeLevel < 0 ? 0 : safeLevel
String hexLevel = percentageToHex(safeLevel.intValue())
BigDecimal safeDuration = duration <= 25 ? (duration*10) : 255
String hexDuration = Integer.toHexString(safeDuration.intValue())
String pluralisor = duration == 1 ? "" : "s"
logging("${device} : setLevel : Got level request of '${level}' (${safeLevel}%) [${hexLevel}] over '${duration}' (${safeDuration} decisecond${pluralisor}) [${hexDuration}].", "debug")
sendEvent(name: "level", value: "${safeLevel}")
void refresh() {
// Battery status can be requested if the command is sent within about 3 seconds of an actuation.
// I considered removing this, but it can be useful for forcing a battery read when the device is to hand.
logging("${device} : Refreshing", "info")
sendZigbeeCommands(zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0021))
def updatePresence() {
long millisNow = new Date().time
state.presenceUpdated = millisNow
def checkPresence() {
// Check how long ago the presence state was updated.
uptimeAllowanceMinutes = 20 // The hub takes a while to settle after a reboot.
if (state.presenceUpdated > 0) {
long millisElapsed = millisNow - state.presenceUpdated
long presenceTimeoutMillis = presenceTimeoutMinutes * 60000
BigInteger secondsElapsed = BigDecimal.valueOf(millisElapsed / 1000)
BigInteger hubUptime = location.hub.uptime
if (millisElapsed > presenceTimeoutMillis) {
if (hubUptime > uptimeAllowanceMinutes * 60) {
sendEvent(name: "presence", value: "not present")
logging("${device} : Presence : Not Present! Last report received ${secondsElapsed} seconds ago.", "warn")
} else {
logging("${device} : Presence : Ignoring overdue presence reports for ${uptimeAllowanceMinutes} minutes. The hub was rebooted ${hubUptime} seconds ago.", "debug")
} else {
sendEvent(name: "presence", value: "present")
logging("${device} : Presence : Last presence report ${secondsElapsed} seconds ago.", "debug")
logging("${device} : checkPresence() : ${millisNow} - ${state.presenceUpdated} = ${millisElapsed} (Threshold: ${presenceTimeoutMillis} ms)", "trace")
} else {
logging("${device} : Presence : Waiting for first presence report.", "warn")
// Primary parse routine.
logging("${device} : parse() : $description", "trace")
updatePresence()
Map descriptionMap = zigbee.parseDescriptionAsMap(description)
if (descriptionMap) {
processMap(descriptionMap)
} else {
logging("${device} : Parse : Failed to parse received data. Please report these messages to the developer.", "warn")
logging("${device} : Splurge! : ${description}", "warn")
def processMap(Map map) {
logging("${device} : processMap() : ${map}", "trace")
logging("${device} : Processing : cluster: ${map.cluster}, clusterId: ${map.clusterId}, attrId: ${map.attrId}, command: ${map.command} with value: ${map.value} and ${receivedDataCount}data: ${receivedData}", "debug")
if (map.cluster == "0001") {
if (map.attrId == "0021") {
// Okay, battery reporting on this thing is weird. It's not a voltage, but a percentage.
// According to the Zigbee Cluster User Guide, the decimal value from the hex should be multiplied by 0.5 to give percent.
// But the readings are all over the shop. Might be worth pairing to the Tradfri hub and checking for firmware updates?
// Hey, in the meantime, let's just fudge it!
state.batteryOkay = true
// Report the battery... percentage.
def batteryHex = "undefined"
BigDecimal batteryPercentage = 0
batteryHex = map.value
logging("${device} : batteryHex : ${batteryHex}", "trace")
batteryPercentage = zigbee.convertHexToInt(batteryHex)
logging("${device} : batteryPercentage sensor value : ${batteryPercentage}", "debug")
//batteryPercentage = batteryPercentage * 0.5
batteryPercentage = batteryPercentage.setScale(0, BigDecimal.ROUND_HALF_UP)
batteryPercentage = batteryPercentage > 100 ? 100 : batteryPercentage
batteryPercentage = batteryPercentage < 0 ? 0 : batteryPercentage
//Integer batteryDifference = Math.abs(device.currentState("battery").value.toInteger() - batteryPercentage)
logging("${device} : batteryPercentage : ${batteryPercentage}", "debug")
sendEvent(name: "battery", value:batteryPercentage, unit: "%")
sendEvent(name: "batteryWithUnit", value:"${batteryPercentage} %")
sendEvent(name: "batteryState", value: "discharging")
} else {
logging("${device} : Skipped : Power Cluster with no data.", "debug")
} else if (map.clusterId == "0001") {
} else if (map.clusterId == "0006") {
if (receivedData.length == 0) {
parsePress(map)
} else {
logging("${device} : Skipped : On/Off Cluster with extraneous data.", "debug")
} else if (map.clusterId == "0008") {
parsePress(map)
} else if (map.clusterId == "0013") {
logging("${device} : Skipped : Device Announce Broadcast", "debug")
} else if (map.clusterId == "0500") {
logging("${device} : Skipped : IAS Zone", "debug")
} else if (map.clusterId == "8021") {
logging("${device} : Skipped : Bind Response", "debug")
} else if (map.clusterId == "8022") {
logging("${device} : Skipped : Unbind Response", "debug")
} else {
// Not a clue what we've received.
reportToDev(map)
return null
@Field static Boolean isParsing = false
def parsePress(Map map) {
if (isParsing) return
isParsing = true
// We'll figure out the button numbers in a tick.
int buttonNumber = 0
// This is a press of the button.
buttonNumber = 1
logging("${device} : Trigger : Button ${buttonNumber} Pressed", "info")
sendEvent(name: "pushed", value: buttonNumber, isStateChange: true)
device.currentState("switch").value == "off" ? on() : off()
if (map.command == "01") {
// This is a turn of the dial starting.
buttonNumber = 2
if (receivedData[0] == "00") {
buttonNumber = 2
state.changeLevelStart = now()
logging("${device} : Trigger : Dial (Button ${buttonNumber}) Turning Clockwise", "info")
sendEvent(name: "direction", value: "clockwise")
sendEvent(name: "held", value: buttonNumber, isStateChange: true)
sendEvent(name: "switch", value: "on", isStateChange: false)
} else if (receivedData[0] == "01") {
buttonNumber = 3
logging("${device} : Trigger : Dial (Button ${buttonNumber}) Turning Anticlockwise", "info")
sendEvent(name: "direction", value: "anticlockwise")
} else {
reportToDev(map)
} else if (map.command == "02") {
// This is a multi-press of the button.
buttonNumber = 1
// Double-press is a supported Hubitat action, so just report the event.
logging("${device} : Trigger : Button ${buttonNumber} Double Pressed", "info")
sendEvent(name: "doubleTapped", value: buttonNumber, isStateChange: true)
// Triple-pressing is not a supported Hubitat action, but this device doesn't support hold or release on the button, so we can use that for triggers.
logging("${device} : Trigger : Button ${buttonNumber} Triple Pressed", "info")
sendEvent(name: "released", value: buttonNumber, isStateChange: true)
} else {
reportToDev(map)
} else if (map.command == "03") {
// This is a turn of the dial stopping.
// There's no differentiation in the data sent, so we work out from which direction we're stopping using the previous hold state.
buttonNumber = device.currentState("held").value.toInteger()
logging("${device} : Trigger : Dial (Button ${buttonNumber}) Stopped", "info")
// Now work out the level we should change to based upon the time spent changing.
Integer initialLevel = device.currentState("level").value.toInteger()
long millisTurning = now() - state.changeLevelStart
if (millisTurning > 6000) {
millisTurning = 0 // In case the messages don't stop we could end up at full brightness or VOLUME!
BigInteger levelChange = 0
levelChange = millisTurning / 6000 * 100
BigDecimal targetLevel = 0
if (buttonNumber == 2) {
targetLevel = device.currentState("level").value.toInteger() + levelChange
} else {
targetLevel = device.currentState("level").value.toInteger() - levelChange
levelChange *= -1
logging("${device} : Level : Dial (Button ${buttonNumber}) - Changing from initialLevel '${initialLevel}' by levelChange '${levelChange}' after millisTurning for ${millisTurning} ms.", "debug")
sendEvent(name: "levelChange", value: levelChange, isStateChange: true)
setLevel(targetLevel)
} else {
reportToDev(map)
pauseExecution 110
isParsing = false
void sendZigbeeCommands(List<String> cmds) {
// All hub commands go through here for immediate transmission and to avoid some method() weirdness.
logging("${device} : sendZigbeeCommands received : ${cmds}", "trace")
sendHubCommand(new hubitat.device.HubMultiAction(cmds, hubitat.device.Protocol.ZIGBEE))
private String[] millisToDhms(int millisToParse) {
long secondsToParse = millisToParse / 1000
def dhms = []
dhms.add(secondsToParse % 60)
secondsToParse = secondsToParse / 60
dhms.add(secondsToParse % 24)
secondsToParse = secondsToParse / 24
dhms.add(secondsToParse % 365)
return dhms
private String percentageToHex(Integer pc) {
BigDecimal safePc = pc > 0 ? (pc*2.55) : 0
safePc = safePc > 255 ? 255 : safePc
return Integer.toHexString(safePc.intValue())
private Integer hexToPercentage(String hex) {
String safeHex = hex.take(2)
Integer pc = Integer.parseInt(safeHex, 16) << 21 >> 21
return pc / 2.55
private BigDecimal hexToBigDecimal(String hex) {
int d = Integer.parseInt(hex, 16) << 21 >> 21
return BigDecimal.valueOf(d)
private boolean logging(String message, String level) {
boolean didLog = false
if (level == "error") {
log.error "$message"
didLog = true
if (level == "warn") {
log.warn "$message"
didLog = true
if (traceLogging && level == "trace") {
log.trace "$message"
didLog = true
if (debugLogging && level == "debug") {
log.debug "$message"
didLog = true
if (infoLogging && level == "info") {
log.info "$message"
didLog = true
return didLog
Besides the very little modification I did, all credit belongs to @birdslikewires .
If any of you guys could help me with getting this thing up and running, I would appriciate it. I got no IT background and I have basically no Idea, what I'm doing, so maybe one of you guys will get it up and running.
