Why hasn’t anyone made this yet? A while ago, I had someone tell me it had to do with electrical code being tricky with allowing always hot light wires, but inovelli and zooz do this...why do you think is hasn’t been done yet? Only thing I can think of is Phillips won’t allow it because they’ll come out with one for $150.
I'm sorry, I'm not understanding the question. The whole point of the Lutron Aurora is that you don't have to change the switch. Smart Bulbs work great for those folks that live in apartments and aren't allow to change the switches. If you are allows to change the switch, why not simply put in a smart dimmer?
You can’t put dimmers on smart bulbs. I live in a house and kinda fell in love with hue. I like bright lights for focus, that warm light for relaxing etc. I want an inwall dimmer for my smart bulbs
Why does it have to be in-wall is what I'm asking.
Do you have a Caseta Pro hub? With Hubitat, you can use Pico remotes to control Hue bulbs. And they can be mounted to give the appearance of "in-wall" or be used as portable hand held dimmers.
Why not install the new innovelli switch that can disable the internal relay so that it works like a button controller and is compatible with smart bulbs?
That was going to be my solution but that isn't an "in-wall" device technically. That's why I wondered why that requirement. Is it look? or Mains powered? Or some other reason?
Have you done that yet? The new firmware hasn't been released yet allowing you to do that for the dimmer devices.
As of this summer, most Zooz firmware has allowed you to effectively control smart bulbs by disabling the relay and using central scene commands from the switch (interpreted as button events by the driver) to control the bulbs, e.g., double-tap down to dim, or whatever you want. This is also how the new Inovelli switches work and, I assume, how the new Inovelli dimmers will shortly.
The even newer Zooz firmware is reported to allow the switch to keep track of level so you could effectively use it like a hardwired Lutron Aurora (which despite looking like a button is actually a Switch and Switch Level device). How well that will work, we'll see.
If it works well, it could basically be what the poster is asking for as long as they're OK with using the switch as a sort of "master" to track level for the individual bulbs.
EDIT: I have since learned that even the current (May/June 2019, not the one they're going to release in fall of 2019) firmware supports "held" and "released" events for the paddle when held up or down. For me, this already does everything I want with smart bulbs, and I'd actually prefer that to something that tracks level (which means I'd need an awkward "mirroring" workaround to make it work as expected). The only feature I'd request is that when local control is disabled, it doesn't disable control from in-wall "dumb" switches, which still cut power to the device. Maybe this will help by providing some option for that? (I understand the difficulty as-is where when local control is enabled it will just toggle the load, but with local control disabled it's not clear what it should do--it certainly can't pick a tap up or down automatically despite a human knowing which they'd probably prefer, so maybe sending another special button event, if possible, would be nice so the human can decide what they want.)
I have not. I use Lutron Caseta devices because I don't have neutral wires in my switch boxes. For a couple circuits with low-voltage lights (which will only work with the caseta dimmers that require a neutral), I went with the solution that @aaiyar mentioned, i.e. connect the line and load wires in the box and install a pico for control via hubitat; since they make a mount that goes in a switch box I went with that option.
But I agree with you that it's unlikely Hue will release a device capable of what the innovelli switch can do, I suspect the market for smart bulb users that want to (or are even allowed to) re-wire an in-wall switch/dimmer for use with smart bulbs is waaaay smaller than the general smart bulb user market.
Additionally, you should consider looking up your local building codes if you have questions about whether certain wiring configurations are permitted. Although there are national standards in the US like the NEC, local governments can vary in the way they implement those standards into local building codes. Or you could always hire an electrician licensed in your area.
"Someone told me [xyz] in an online forum" is unlikely to impress the local fire inspector or your insurance company in the event of an electrical fire...
Zooz doesn’t dim, or I would
The zooz doesn't support the release function. Only pushed or held. Is my understanding.
And the new firmware will create a dimmer device while keeping the load always powered. What Zooz has not answered is how it will handle "ramping". Currently, dimmers don't report their level till you release the paddle. Which would make them useless in dimming smartbulbs. You wouldn't know what the level was going to be until you released the paddle. And then it's a crap shoot. Zooz has no answer to that question that I have asked several times.
I forgot to mention above that there's an another in-wall control device for Hue besides those mentioned above, the Click for Hue by RunLessWire: https://runlesswire.com/click_philips_hue/. Unlike the others, this one isn't battery-powered; it's Zigbee Green Power like the Hue tap, so it's powered by the kinetic energy from the button presses. It's still not mains-powered if you insist on having a mains device for some reason (a switch or dimmer with the relay disabled that will still report button events is as close as I've seen there), but it's still something else you could consider.
EDIT: And I forgot about the RGB Genie mains-powered controllers Hubitat added support for this summer!
I saw those and was thinking about picking one up to see if it could pair to HE but I couldn't find if it was Touch Link or not.
I'm curious too, but given that it uses Zigbee Green Power, I'd doubt it would work on Hubitat or even pair at all. Even if it did--and I have a Hue Bridge where I could (and probably would) use it instead--the $60 pricetag is there to stop me (think of all the Picos I could get instead!
For my one RGBW controller, I use a RGB Genie 5 button Zigbee remote. It works fine with Hubitat. Two of the buttons I programmed for dim/brighten, and the other two buttons are used to cycle through colors. There is even a scene button you could program for a favorite color/brightness.
It would be a good alternative to Pico remotes if you didn't have a Lutron bridge. It is more costly than a Pico, but much cheaper than Pico and a Bridge Pro. It mounts like a Pico does, so it is compact and no wiring is involved.
Is it possible to use a Pico to cycle through the basic colors of a Hue bulb? I have a Lutron Pro Bridge integrated with Hubitat. The Hue bulb is paired directly to Hubitat.
Actually, they sorta answered this in one of my posts.
She didn't give a "This is how it will work 100%" type answer, but said the goal is to make it work the exact same as a normal bulb, and a normal bulb dims/brightened in real time as you hold the paddle buttons down.
Our goal is to have the dimmer report brightness level in real time. The beta firmware is ready so if there are any volunteers with a smart bulb set-up and our dimmers on hand, please pm me!
