I've just bought a new C8 hub and was about to register for Hub Protect on it, and I noticed in the threads that I should email you to temporarily enable cloud back ups on my old hub so I can transfer these across.
Two answers I can't find are:
Can you enable cloud backs on two hubs (my c7 for zwave devices, and my C5 for ZigBee devices)? Or should I register for hub Protect on one of my older hubs, do that transfer, and then move the Hub Protect subscription to my second old hub and do that transfer (and then move my subscription to the new C8 hub )?
Can I re-order my zwave devices when transferring them across? I want to rebuild my zwave mesh so it is stronger so want some devices to get added before others so the mesh is stronger
You can subscribe an old hub, perform a cloud backup that you'd migrate to the a new hub, then transfer the subscription to the new hub, afterwards.
But best of all, one time migration from an old hub to a C-8 hub comes free and doesn't require Hub Protect.
A one time cloud backup is enabled by default on every hub, but you can only use one cloud backup from one hub to migrate to a C8. The C8 hub cannot accommodate merging different cloud backups from more than one hub.
No, the migration process is a replica of the old hub with the bad and the good included. If the Z-Wave network on the old hub has issues, likely those issues will follow you on the new hub, unless the current issues are related to range. In that case, the new C8 hub with its external antennas may be able to perform better.
As for adding devices you can do that once your migration is completed. You can add more mains power devicess (repeaters) to strengthen the mesh. The hub will rearrange its devices on its own. You can perform a Z-Wave Repair to speed up that process, but repair is not required.
This topic has been marked solved by the community and subsequently closed. If the issue persists, or for further discussion on this topic, feel free to create a new thread under a different category to continue the conversation.
If you are logged in, click [HERE] to get started.
