Hey there,
I'm working on a little project and I will need some product recommendations. I'm planing to build a smart coffee machine. What I got right now is a machine with an integrated grinder. Getting it into Hubitat and my smart home itself shouldn't be all that difficult, as I'm planing to use the Shelly UNI, which is build for those kinds of applications. The tricky part, more or less, will be the features, I want to integrate, so that my lazy ■■■ has as less work as possible with this.
I want to be able to tell my Google Assistant not just that I want coffee, but also how much coffee and when, without the need to prepare the machine in any way. Achieving this, I was thinking about 3 additional parts that I require.
Valve
Water Sensors
A bean dispenser
The first two parts to fill up the water tank, the last for coffee (duh! ). The end product should look like this:
The Water sensors should be used in combination with virtual switches, shutting off the valve, when a certain water level is reached (Rule: IF Switch is on and water sensor X reports -> shut off valve).
What I need now are recommendations for these three parts. I prefer Zigbee, because I have zero Z-Wave products and in conclusion no stable Z-Wave-Mesh.
For the valve, I was thinking about this one:
According to the list of compatible devices, it should work, but I don't know, how fast and reliable it is. Has anyone any experience with this device?
For the water sensor, I have no idea, which one to choose. It should be reliable, but not that expensive, because I would need five of them.
Same problem with the bean dispenser. I was thinking about using a dumb dispenser and making it smart somehow, another problem I currently have no solution for.
Now my little think tank, let us pool our brains together.
