Dimmer setLevel() without Turning On
I didn't see the user manual with a quick search of the net. But if you can find that setting (parameter number) you can set this by using the Basic Zwave Tool. Super basic Z-Wave parameter tool
You basically download this code to your hub, change the device type (driver) to this tool temporarily, and from there you can read and set the hidden parameters. Once you get it set, you change back to the normal driver.
