I have 8 motion sensors to trigger Lutron switches and Hue lights around my home. 3 of the motion sensors are 4 year old Hue sensors that I ran off of a Hue hub prior to my Hubitat, but have been running them on Hubitat since. Since I began using Hubitat, I've expanded using Hue and AGSHome Zigbee motion sensors depending on whether the room received enough daylight to make use of the light sensor in the Hue.
Everything has always worked wonderfully until........... Hue's new motion sensor that, as best I can tell, started distributing this year.
This month, I put a Lutron Caseta dimmer switch in my primary bathroom, and I wanted it to trigger with a Hue motion sensor. It detected just fine, but it wouldn't communicate again after the initial setup. I deleted and readded it several times, and thinking perhaps it was a communication issue, I added it the last time with it right next to my Hubitat. Every attempt was the same: It would add without issue, but would not communicate again.
On a hunch, I setup the new Hue sensor in the Hue app on the Hue Bridge, and there were zero issues, BUT that makes a horrible pain to utilize my Lutron switch.
I managed a workaround to get my needs met: I have a room that had some old Hue bulbs and an old Hue sensor. I swapped that sensor into my primary bathroom, and its functioning just like I wanted it to with my new Lutron Caseta dimmer. I took the new Hue sensor and connected it to the Hue app/Bridge and moved it into the room that has the old Hue bulbs, and its functioning outside of Hubitat entirely via Hue.
Here is the info my Hubitat listed for my older Hue sensors:
model: SML001
application: 02
firmwareMT: (varies)
softwareBuild: (varies)
manufacturer: Philips
The new Hue sensor seems to be a different manufacturer, and it doesn't give firmware or software data:
endpointId: 02
model: SML003
application: 02
manufacturer: Signify Netherlands B.V.
In light of this issue, if anyone can give me a recommendation on how to get connectivity from a new Hue sensor, or another quality motion and light sensor for any future expansion needs, I'd greatly appreciate it!
There may be some driver tweaks needed to make it work.
