I migrated from a C7 to a new C8 hub following all the correct steps posted at How to Migrate to a New Hub | Hubitat Documentation, but now none of my devices are responding neither to automations nor to direct commands adressed through the device page.
I choose to migrate the Zigbee radio, and my devices appear on the Zigbee details page under the Settings menu, but none is responding.
Any tips other than repairing more than 100 devices?
Did you turn off the C-7? The Zigbee radio on the C-7 is a duplicate of what you migrated to the C-8. If it's still ON, then the C-8 isn't going to pry the devices away.
I hope you have not reset the radios, because you may want to revert back if the advice the community offers doesn't solve it for you...
Yes @csteele, my C7 is turned off. The problem seems to be with the C8 radio: to test if it would recognize a device, I tried to repair a switch.
The search found the device, recognized it as a previously paired device, but is unable to control it. The led indicator of the switch continues blinking indicating it is not paired!
Just to confirm - where did you do this repair? There is a Z-Wave Repair available on the Z-Wave Details page, but there isn't an option to repair individual Zigbee devices.
Example of Z-Wave device Repair button on Z-Wave Details page:
I thought above you said you had only migrated Zigbee devices. Do I misunderstand? Are we talking about Z-Wave devices, Zigbee, or both? And not one of them is working?
Thank you, but I know it is very limited and sometimes it causes misunderstandings.
I tried to reboot the radio and rebuild network, both without success. Now I made another C7 migration backup, made a software reset on C8 and I will try to migrate another time...
I'm starting to think there's a problem with the zibee radio.
I redid the migration, disabled and re-enabled the C8's Zigbee radio, rebooted it and rebuilt the network, all all unsuccessful.
There appears to be no communication between the hub's radio and the devices, as I tried to re-pair a switch, the hub found it but the device continued to seek connection. That is, the device did not receive the response from the hub ...
I read about this swap in another topic and I already tried too, but didn't work... The Zigbee empty log is making me suspect a hardware failure.
I'm doing another soft reset and I'll try to add a Zigbee device to C8 before to make the migration, if succeed this may rule out the possibility of a hardware error, and isolate the error at the migration process.
I tried pairing a Philips Hue motion sensor that was inches from the hub, and the result was the following message:
Looks like youโre having trouble pairing your device. Please perform a factory reset before attempting to pair the device again. If the device still wonโt pair after factory reset, please review the best practices for building a solid Zigbee mesh.
If a device was found but got stuck in the initializing stage, try pairing it using the legacy pairing method.
I believe I got lucky with a faulty hub I bought through Amazon. And the worst thing is that I'm back in Brazil...
Yep. The worst to me is that I'm back in Brazil, so if I need to send the device to Amazon I'll pay more than its price in customs taxes to receive another one...
Only thing I can think of is to reiterate this... C-7 needs to be physically disconnected from power once it has 'donated' its PAN ID /Ext. PAN ID to C-8 after migration; its radio will still be 'alive' at the Zigbee link layer and maintain connections to devices even when its radio is set to 'disabled' (that just affects higher levels of the protocol stack).
