Ok.. I must be missing something here..
I made a tiny app to push a button on a schedule
FYI this is to force a button to report to HE so I know it hasn't dropped off the network
So.. according to this post by @mike.maxwell:
The command should just be:
device.push(button_number)
So look at this...
INPUTS
section() {input (name: "startTime", title: "Action time", type: "time", required: true)}
section(){input "buttonA", "capability.pushableButton", title: "Button", multiple: true, required: true}
section(){input "buttonNumber", "number", title: "Select Button Number", required: true }
Method called by a cron job (set by the 'startTime' input:
def pushNow1() {
LOGDEBUG("Scheduled operation running now...")
LOGDEBUG("Pushing button $buttonNumber on $buttonA now...")
buttonA.push(buttonNumber)
// buttonA.push(1)}
Everything appears to work in the logs..
but the button doesn't get pushed..
I even tried hard coding: 'buttonA.push(1)' but that didn't work either.
I have tried this with a physical button (hue dimmer) and a virtual button.
Neither one worked.. (both work with the push command on the device page)
Am I being stupid here or has something changed?
@mike.maxwell ??
Andy
