I have a GE/Jasco outdoor plug that I use for Christmas lights. It was working an then about a week ago it stopped updating it's state. I noticed because it said it was on when I looked at it during the day but the lights weren't on. I've tried refreshing state, repairing z-wave network, etc. but it still says current state: on. Now if I'm in the device configuration and I select on/off then it functions and does turn the outlet on/off.
The device driver is Generic Z-Wave Outlet and device data is as follows:
deviceId: 12592
deviceType: 25443
manufacturer: 99
inClusters: 0x25,0x27,0x75,0x73,0x86,0x72,0x77
Notice the throughput speeds - 40 kbits and 100 kbits.. this is indicative of a good route back to the hub. If you are seeing 9.6kbits it could mean that the mesh is having some issues either weaker signal to the outlet or some device flakiness somewhere in the route.
I have a C-5 (Platform Version 2.2.4.158) and unfortunately it doesn't look like I have that information in my Z-Wave Details page. Disappointing that I will have to buy a C-7 and go through device migration to display device routing... ugh.
Did you ever find a good resolution to this issue?
I have a GE Enbrighten dimmer that works fine (goes on and off visually), and responds to Rules and such, yet constantly reports itself as "Off" on its Status page, even if I click the "On" paddle (which, as I said, does turn on the actual lamp plugged into it).
Not sure how to tackle that myself...
EDIT: Found a "solution" of sorts, namely changing the Device Driver from "GE Enbrighten Z-Wave Smart Dimmer" to "Generic Z-Wave Smart Dimmer" (which sadly eliminated the "Fade" parameter). Now, "On" and "Off" getting reported accurately.
