Thanks for that (and also for the time you've put into the drivers! )
On a new note I know you've mentioned somewhere that we have no control over the reporting frequency for the aqara temp/humidity sensors but it's the only xiaomi device that seems to burn through batteries (1-2 months max, whereas my other sensors are still running 1 year on). Would the original xiaomi ones be a better bet? I really don't need to know the temps every other minute
There is a mod out there in one of the threads that will allow the sensor to be ready to report motion every 5 seconds instead of the default 60 seconds.
Have a search you may find it or can someone else point us in the right direction?
It is the normal behavior, and can't be changed programmatically. However...
It can be changed with a fairly simple hardware modification, if you're not afraid to open up the motion sensor:
And here are some additional notes by Hubitat user @SmartHomePrimer:
Hmm, I have bunches of both the Xiaomi and Aqara-branded Temp-Humidity Sensors and all of their batteries have lasted well over a year, with the one exception being an Aqara sensor I've mounted just outside my front door. I am not surprised by the shortened battery life on that one because of the colder temperatures.
Either way, the Xiaomi-branded sensor reports based on temperature / humidity changes, the same as with the Aqara one, so you wouldn't see much difference in the frequency of reporting. I honestly don't have enough data with battery life to know which of the two lasts longer given the same battery brand / age.
I have 65 Aqara Temp/Humidity/Press sensors running for about six months now, the only ones where the batteries show a significant voltage drop are outside in the cold. The indoor sensors have an initial voltage drop during first week or two then stabilize.
I notice this with both temperature and humidity on one of my sensors as well, but it's one that I've kept outdoors (covered, but outdoors) and just figured the weather finally got to it. It did it even when I took it inside for a while (wasn't sure if sub-0-degrees C temperatures were special; I know they've been problematic before). None of my other sensors--all of which have remained indoors the whole time they've been in use--have been doing this.
I'm not sure exactly how these two anecdotes would connect unless perhaps the bathroom has excessive humidity on occasion or it's very near a water source (I wouldn't doubt that there's been condensation on or at least near my outdoor sensor at some point). I told myself that at this price, I don't care too much...but I am trying to figure out how to get the several-hundred-degrees-below-zero readings out of my Home Assistant history graphs.
All the surrounding values are normal. It would report in something like "37.5, 38.0, 37.5, 37.0, 654.4, 37.5, 37.0 etc" It shows up almost every hour and the correct humidity is reported almost right after as well. So its like this message is a status message of some sort.
The raw command is always the same when it send in that weird reading. Its doing it on all of my sensors so I'm wondering if its something that was changed in 2.1.7. I'm usually running the latest beta but that one is now released to all.
For now I just filter out that value so it doesn't affect me, but something to keep an eye out for. I only noticed it because my bathroom fan automation was kicking in randomly and this is the reason why.
No more dropouts since increasing the mesh from 6 to 11 routers per building. Not sure if my heterogeneous mixture of routers has anything to do with it.
4 IKEA plug outlets per building
6 CC2531 routers per building
1 Aqara plug per building paired only as a device
Well here's an indication of how busy I've been since the summer: My hub is still running 2.1.5.124, though I could swear I had updated to 2.1.6.
Anyhow, I've looked through all the release notes of 2.1.6 and 2.1.7 and see nothing that would indicate a change to the Zigbee stack, which is the only thing I can think of that would alter how messages received from the sensor are parsed.
I've backed up some hours of old logs from a couple of my T/H sensors, and will now update to 2.1.7.125 to see if there's a change. My suspicion is that there may be some messages which are part of the hourly check-in that were previously filtered out but are now passed on to the driver as of firmware 2.1.7. If true, then I just need to add code to filter out the non-useful messages that are producing the out-of-bounds values.
I'll report back when I've seen enough logs to know either way.
Interestingly enough, three of my sensors eventually had their battery die and I replaced the batteries.. I just looked at my past logs and have not seen it report on those threerecently. However my two other sensors are still kicking the error every now and then.
Just a wild thought but wonder if its related to the battery about to die. I'm going to keep an eye on things and see if these other two sensors are going to die any time soon.
I am on Xiaomi Temperature and Humidity Sensor and using Version 0.8.2 of the driver by veeceeoh.
I notice that after adding it to Hubitat, the sensor stops reporting readings 1-2 hours later. For example, after adding the sensor at 5AM, I receive readings whenever there are changes in temperature/humidity. This goes on until 1-2 hours later when it goes silent.
I tried to use 'Discover Devices' and Hubitat was able to detect the sensor and readings are reported fine but this time, the readings only lasted for 30 minutes or so.
Battery level is 100% and I had removed and re-added the sensor as well.
Just wondering if there's any step I had missed out:
Activate device discovery on Hubitat
Long press button on Xiaomi temperature sensor
Hubitat found sensor and tried to add it (in my 2nd attempt to re-add the sensor, I had also short press the sensor repeatedly to keep it awake)
Do you have any Zigbee repeaters, though? Distance is not the only criteria Zigbee devices use when choosing their routes, and there's no guarantee that the first they choose is the one they'll stay with (though I have yet to see a Xiaomi device of mine change, some people say they have--I do see standard Zigbee devices change), nor is there any guarantee that being close to the hub means they will route directly to it (though it is a logical assumption with that small of distance).
Given people's experiences above and in the other thread on this subject, I'd recommend that all your Zigbee repeaters be "Xiaomi-friendly."
I do have zigbee devices that act as repeaters around the house, i.e. IKEA TrΓ₯dfri power outlets which I understand they are Xiaomi friendly. Just that the sensor is nearer to to Hubitat than to the repeaters.
Again, thanks for the input - I will also troubleshoot by removing and re-adding the sensor by placing it close to the repeater (on top of doing the same with the sensor closer to Hubitat).
