[UPDATE] v0.3.1b of Xiaomi Mi Cube Controller device driver for Hubitat
After more testing with the v0.3b update, I realized that the method to set the number of buttons according to the Cube Mode selected in preferences wasn't working correctly. Also, I saw that the cube occasionally sends catchall: messages which are of no use, but produce (harmless errors.) Those issues have been fixed. Finally, I re-did the fingerprint data used to match the driver to the cube during pairing, it's working perfectly (for me, at least.)
The updated device driver code can be grabbed from here.
PLEASE NOTE: This driver is still in beta, and its features and functionality may change.
Change List
- Added conditional check for
catchall:messages to avoid unwanted java exception errors - Removed unused
EnrollResponsecommand andActuatorattribute - Edited fingerprint data to improve selection of driver during pairing
- Fixed issues with setting the correct number of buttons according to the user-selected Cube Mode
With the above v0.3.1b update, I am unable to replicate your experience. Here's some log output to show repeat gestures working just fine with my cube (note the entries below are reversed from normal output order, so the first is on the top, last is on the bottom):
Sample cube log output (click arrow to reveal)
12:10:15.239 am [info] Mi Cube: Updating preference settings
12:10:15.249 am [info] Mi Cube: Number of buttons set to 36
12:10:15.251 am [info] Mi Cube: Info message logging enabled
12:11:40.574 am [info] Mi Cube: Rotated by 29°
12:11:40.619 am [error] java.lang.NullPointerException: Cannot execute null+19 on line 349 (parse)
12:13:08.174 am [info] Mi Cube: Stale face data, updating
12:13:08.179 am [info] Mi Cube: Flip to face #3 detected (button 4 pushed)
12:13:08.182 am [info] Mi Cube: Knock detected with face #3 up (button 16 pushed)
12:13:12.928 am [info] Mi Cube: Rotated by 34°
12:13:12.951 am [info] Mi Cube: Right rotation on face #3 (button 22 pushed)
12:13:18.361 am [info] Mi Cube: Rotated by 16°
12:13:18.370 am [info] Mi Cube: Right rotation on face #3 (button 22 pushed)
12:13:23.163 am [info] Mi Cube: Rotated by -24°
12:13:23.170 am [info] Mi Cube: Left rotation on face #3 (button 28 pushed)
12:13:25.559 am [info] Mi Cube: Rotated by -20°
12:13:25.585 am [info] Mi Cube: Left rotation on face #3 (button 28 pushed)
12:13:31.730 am [info] Mi Cube: Flip to face #5 detected (button 6 pushed)
12:13:36.770 am [info] Mi Cube: Flip to face #0 detected (button 1 pushed)
12:13:40.957 am [info] Mi Cube: Knock detected with face #0 up (button 13 pushed)
12:13:44.846 am [info] Mi Cube: Flip to face #1 detected (button 2 pushed)
12:13:47.355 am [info] Mi Cube: Knock detected with face #1 up (button 14 pushed)
12:13:52.053 am [info] Mi Cube: Shake detected with face #1 up (button 32 pushed)
12:13:54.699 am [info] Mi Cube: Shake detected with face #1 up (button 32 pushed)
12:13:57.767 am [info] Mi Cube: Shake detected with face #1 up (button 32 pushed)
12:14:03.625 am [info] Mi Cube: Stale face data, updating
12:14:03.630 am [info] Mi Cube: Flip to face #2 detected (button 3 pushed)
12:14:03.635 am [info] Mi Cube: Slide detected with face #2 up (button 9 pushed)
12:14:06.497 am [info] Mi Cube: Slide detected with face #2 up (button 9 pushed)
If you are concerned about the driver not acting on messages received from the cube, then enable debug message log output, then you'll see every message the driver receives from the cube. Look for entries that start with Parsing message:
What I see, with my cube at least, is that it doesn't send a message every time I interact with it. For example, I have to be deliberate when I flip it, rather than moving it gently, in order to generate a "flip" message.
Also, if using the Advanced or Combined Cube Mode, keep in mind that sometimes the driver loses track of which face is up if the cube is moved in some way without causing any message being sent. For example, I can rotate the cube around in mid-air, gently set it on a surface, and the driver won't know which face is up anymore. The original author wrote code to extrapolate that as best as can be done, but it's an imperfect science. I will be adding a much more complete post on this thread soon to explain how the driver works as it stands right now, along with all the caveats and limitations due to the way the hardware itself works.
You probably noticed there is a java exception error in my sample log output. This is because it's log output from right after I freshly paired the cube, and the driver doesn't have any way to know what face is up if the first thing you do is rotate it. That's something I need to fix, but it's resolved as soon as another type of gesture occurs which supplies face up data. I'll get to fixing it soon, but that error is not breaking anything, though.
EDIT: I just noticed that my cube is reporting it's battery voltage at 2.735 Volts, below the minimum Volts value, so the percentage is calculated at -110%! It's still working fine, so perhaps I need to consider a lower min Voltage threshold for this particular Xiaomi device. Regardless, I'm going to get a new CR2450 just in case the original battery is near the end of it's useful life. Any observations from other cube users on reported battery voltages would be greatly appreciated!
That's wonderful news! I am going to keep it as a beta until I hear from at least a couple other people with the smoke detector, and then I'll make it "final".
By the way, I de-selected the "Solution" tick-box, because this thread isn't really about trying solve a specific issue.
Thanks again for testing the fixed code and reporting back here, much appreciated!
