Never mind. Spoke too soon. Device status wasn’t reporting correctly with these drivers. How to implement device presence with the generic drivers
No drivers that implement "presence" in either my Hubitat z-wave mesh, or my Hubitat zigbee mesh. Nothing has dropped off either mesh - even when my hubs were turned off for about 2 weeks in the aftermath of Hurricane Ida.
Thanks - I finally got two of them to pair. I started all over with the switches literally a couple inches from the hub. I still had to rediscover them a few times but eventually it worked. Seems like the "recipe" is putting them very close, pressing the switch on back repeatedly during the pairing, and repeating the include process without removing the device a few times until it starts to respond. Kind of weird.
Is there a way to entirely disable the "presence" object? I've tried "enable presence"=off, however, through Maker API I'm still getting JSON node for Presence. This does odd things with HomeKit integrations, hence why I want to get rid of it.
Which HomeKit integration are you using?
I'm running a docker image of onzu-homebridge on a Synology device.
Hi Guys!
My first post here after the migration from ST (ongoing) so bear with me
I have a couple of Aqara Wall Switches , QBKG24LM to be precise.
I have installed the following driver for them:
My issue is that I cannot see the "hold" button option. As far as I have read on this thread, there is a way to reproduce this by using push&release but not sure how.
What I am trying to do is to create a webcore piston that when the button1 is held, something happens.
Can you please guide me on how to do this "hold" action?
Thanks ,
Vlad
thanks for your driver.
can i ask driver Aqara Cube MFKZQ11LM?, not MFKZQ01LM
Aqara Cube (works with model MFKZQ01LM) is not worked with MFKZQ11LM.
Summary
pairing info is
| Manufacturer: | LUMI |
| Endpoint 01 application: | 1C |
| Endpoint 01 endpointId: | 01 |
| Endpoint 01 idAsInt: | 1 |
| Endpoint 01 inClusters: | 0000,0003,0001,0012,0006 |
| Endpoint 01 initialized: | true |
| Endpoint 01 manufacturer: | LUMI |
| Endpoint 01 model: | lumi.remote.cagl01 |
| Endpoint 01 outClusters: | 0000,0003,0019 |
| Endpoint 01 profileId: | 0104 |
| Endpoint 01 stage: | 4 |
| Endpoint 02 application: | unknown |
| Endpoint 02 endpointId: | 02 |
| Endpoint 02 idAsInt: | 2 |
| Endpoint 02 inClusters: | 0004,0003,0005,0012 |
| Endpoint 02 initialized: | true |
| Endpoint 02 manufacturer: | unknown |
| Endpoint 02 model: | unknown |
| Endpoint 02 outClusters: | 0004,0003,0005,0012 |
| Endpoint 02 profileId: | 0104 |
| Endpoint 02 stage: | 4 |
| Endpoint 03 application: | unknown |
| Endpoint 03 endpointId: | 03 |
| Endpoint 03 idAsInt: | 3 |
| Endpoint 03 inClusters: | 0004,0003,0005,000C |
| Endpoint 03 initialized: | true |
| Endpoint 03 manufacturer: | unknown |
| Endpoint 03 model: | unknown |
| Endpoint 03 outClusters: | 0004,0003,0005,000C |
| Endpoint 03 profileId: | 0104 |
| Endpoint 03 stage: | 4 |
problem log is
[warn] Unhandled Event PLEASE REPORT TO DEV - description:read attr - raw: CDFB01000012040042044C554D49, dni: CDFB, endpoint: 01, cluster: 0000, size: 12, attrId: 0004, encoding: 42, command: 01, value: 044C554D49 | msgMap:[raw:CDFB01000012040042044C554D49, dni:CDFB, endpoint:01, cluster:0000, size:12, attrId:0004, encoding:42, command:01, value:LUMI, clusterInt:0, attrInt:4]
Good day sir,
I was wondering if you ever got around to coding a driver for the Aqara T1 family of products? I have the T1 Pro cube and would love to get it going on this platform. It was given to me, so I do not have any other Aqara product like their hub to pair with. This is not a product line I care to follow, so if you have one great. If not, no biggie, I will pass this one to someone else.
I just come across your post as I was reading about the M2 and I had a very similar situation in particular with Hive. May I just ask... are all the HomeKit and Zigbee devices connected to M2 also 'visible' on HE as well??
thanks
The short answer is no, the devices available on HomeKit are not exposed to Hubitat.
thanks for the info.
May be I have confused myself. But how does the M2 reports its connected device to HE? is it through its HomeKit connection to a Home Hub.
@andydvsn 's Hive device I guess is connected to HomeHub instead of M2??
link to all these. I am thinking of getting the FP2 sensor. and my real question is , do I need a M2 hub
thx
The devices connected to Aqara M2 hub are exposed to HomKit, as this is there is a direct integration from Aqara to Apple home automation systems.
Hubitat also has a one-way integration to HomeKit - HE devices can be exposed to HomeKit.
Apple does not allow HomeKit devices to be exposed to any other HA system, however.
The workaround is to use Hubitat virtual devices. If a HE virtual device status is changed from the HomeKit automation, its changed status is available in Hubitat.
For example - this is one of the possible ways to bring Aqara FP2 Presence Sensor to Hubitat:
This automation turns on a virtual presence device in Hubitat. There is a second automation made in HomeKit, which turns the virtual presence sensor off when the FP2 presence status is off.
For Aqara FP2 presence sensor you do not need a M2 hub, as FP2 is a WiFi device (not Zigbee or Thread).
thanks for explaining. very useful
Hi there,
I have a Aqara wall switch with double rocker using this driver (thanks so much!) It nicely sets up 2 x child virtual devices as generic switches for each of the rockers. All works fine turning them on/off individually on the device page, they do not interact and work great. However, when I add one of the child devices to a dashboard, pushing the tile turns both of the child devices on/off. I can see in the dashboard debug log that it sends a command only to one of them, in the device log I can see that only one end point is turned on or off, but both child switches change state.
Any ideas? Let me know if more info is needed to debug?
Hi!
There are many postings of drives for Aqara, and I can no longer tell which would be the latest and actually work properly.
For example the Aqara switch drive, so far I have not found a solution for when we command manual, that the status in HE is updated.
If anyone can help by trying to consolidate that would be a latest version.
Thanks.
There are no known active developments for Hubitat platform for the new series of Aqara wall switches and remotes. The existing old drivers will work with the old models.
Which of the older drives do you then recommend using for switch (1 gang 2 switch), humidity/temperature, motion and FP1 presence?
It is time to find a new home for Markus’s drivers, so that more Hubitat community developers can contribute on adding these new Aqara devices that are currently not supported.
Such a process (moving all of the Marcus’s drivers into HubitatCommunity repository on GitHub) will take time however.
Meanwhile, you can try to find a driver for your Aqara device in this list.
Probably the most difficult to handle are the new E1 series of Aqara wall switches. Currently Marcus’s driver supports 12 different switches models , but there are at least 3-4 newer models that needs to be added.
If anyone has successfully modified and tested these drivers for the new Aqara switches, please let me know. I will try to merge the modified code into the original driver.
