Dec 20, 2022. Migrating to Kasa Built-In Integration Recommendation
I do not recommend existing Kasa Community Integration users migrate to the built-in app. I recommend that new users utilize the Built-in app.
For those who have already migrated. The devices will work normally. If you have not set STATIC IP Address, do so at your earliest convenience. The only work-around currently is to uninstall and then reinstall the device (whether installing via the built-in or community app).
Reason for recommendation: On migrating to the built-in integration, things appear to go well with all devices integrated and as children. However, once the hub undergoes a reboot, all devices are orphaned from the application. There is NO IMPACT on day-to-day LAN operations of the devices. Impacts are:
- Future device installation will offer existing devices for installation. This will cause an error (and possible confusion) if selected. The new selection will not install; however, the old will still work.
- If you have not set static ip addresses (AS INSTRUCTED), the recovery by running discovery in the app will not work.
- Some of the data on the multi-plugs are coordinated through the app (again, no major impact.
- You will not be able to connect to a device via the CLOUD.
Testing done (on my C-7 development hub):
I performed 5 test runs to assure consistency.
- Installed the community integration with 5 devices.
- Installed the built-in integration and did a migrate
- Validated children were in the built-in and not in the community application database.
- Did a hub backup (just in case)
- Reboot with community app still installed
- Children migrated back to the community app
- Reboot after removing the community app
- Children were orphaned
Final note: my objective (at 74 yo) is have Hubitat take over the integration and no longer have the community integration. This is still at least a year away.
