Updates for the Inovelli LZW41/LZW42 Multi-White and Multi-Color Bulbs
Improved speed / reduced packets on Color and CT set operations
Increased reliability of reporting
Added color fade time prefrerence for smooth Color and CT transitions
* Copyright 2020 Bryan Copeland
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Inovelli Bulb Multi-White LZW41
* As of 4/9/2020 there is no inovelli code remaining in this driver
* update by bcopeland 4/9/2020
* major re-write for new coding standards / cleanup
* stabilization of color temp reporting
* re-organization of device data for standardization / addition of serialnumber, hardware ver, protocol ver, firmware
This file has been truncated. show original
* Inovelli Bulb Multi-Color LZW42
* stabilization of color temp and color reporting
I have issued a pull request for these changes to get them back to the official repository:
InovelliUSA:master β djdizzyd:master
opened 02:00PM - 11 Mar 20 UTC
Just pushed a major update to the bulb drivers LZW-41/LZW-42:
re-work of associations
Fix of long-standing bug in lowest value of CT range..
This update should also help alleviate delay issues when sending commands to many bulbs at once..
I recommend hitting configure on your devices after updating.. But this is not required..
You can get them now from:
I have issued a pull request to Inovelli's official github:
InovelliUSA:master β djdizzyd:inovelli-new
opened 05:28PM - 09 Apr 20 UTC
Tagging @ericm
@bcopeland Bryan, why do both drivers seem to refer to the 41 for both?
Oops.. Missed the comments.. The drivers are almost identical .. so I started from the same base.. Fixing comments now..
fixed and pushed.. thanks for pointing that out @razorwing
This pull request has already been merged you can get them from inovelli official github
dan3
April 9, 2020, 10:15pm
129
does this pr include the previous fix by another user?
It doesn't as it is based on what was current and that pull request wasn't accepted.. But I'll look into it...
InovelliUSA:master β npk22:LZW42_dimming_speed
opened 09:17PM - 09 Apr 20 UTC
It's a pretty simple add.. I can get it included ..
Updated
added duplicate event filtering (optional as it has a slight possibility of causing issues with voice assistants)
changed dimming speed default to 1 to match previous default functionality
duplicate event filtering is a preference option as it has a slight chance, if the values don't change, that voice assistants will report the device is not responding.
These changes have been merged..
Update to the LZW42 Multi-color bulb:
fixed bug in CT report
added gamma correction as an optional setting
Pull Request:
opened 07:57PM - 15 Apr 20 UTC
I am maintaining these drivers on my repo from now on, there is no code remaining from inovelliβs release.
@bcopeland Do you have the 42? I see both are 41.
Oops messed up the links.. Fixing now.. Thanks for pointing that out
going back and correct the links on the earlier post
