Thanks. I am assuming we should get all future updates for these bulbs from you from now on. I will change the import url.
That’s where I’ll be continuing development.. So if you like my work then yes..
I definitely like what you do, so I will make the change. Thanks again.
I've had these bulbs for some time but never installed (because I have Hue bulbs). Thinking of using this now because I can associate it with my Inovelli dimmers and always get instant responses (even when HE decides to slow down on me).
Couple of questions please:
- How does this bulb compare to the Philips Hue White and Color Ambiance Bulb?
- I noticed that at times, setting colors take a few seconds to respond. Is this normal? Is it a firmware issue? My Hue bulbs are always pretty much instantaneous.
since I do not own any Hue devices.. I have no idea..
Not normal .. Could be mesh issues.. (weak signal perhaps).. Could also be you just need to do a z-wave repair
Weird. I have a bunch of Inovellis switches and dimmers and those are all repeaters so don't expect mesh issues. I'd do a zwave repair now though.
Thanks for your response
There's something interesting going on here. The color takes a while to change when it has recently been changed and it now appears to be because there's a lot in the logs after a color change.
Here are my logs when I change the color of a bulb.
Nice driver. Just started using it last night after my first Illumin bulb arrived. I might have missed this in the thread, but is there a way to get simple logging to show up in the Hubitat logs? I noticed that nothing is showing in the logs for this device. Is debugging the only option?
What kind of logging are you looking for?
Nothing fancy. Just something that shows the bulb turned on/off at a certain time, as well as what color or CT it was set to. I have other devices that show this info without debugging being turned on.
I can add descriptive logging.. I didn’t prior because I felt it redundant with the events..
But.. I’ll add this
This is exactly what I was looking for. Seems to be working great! Thanks!
@bcopeland Any ideas about the LZW42 slowness? I just updated to your 2.1 driver and captured a log. This is what I did (all via the hubitat UI): 1) Turn ON Bulb 2) Set Color1 [this was instant] 3) Set Color2 [this is slow] 4) Turn OFF Bulb [did not wait for Color2 to happen].
dev:2332020-05-07 09:27:44.985 pm warndebug logging disabled...
dev:2332020-05-07 08:58:35.569 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:35.537 pm infoDining Room Outdoor Light Bulb color is Rose
dev:2332020-05-07 08:58:35.482 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:35.471 pm infoDining Room Outdoor Light Bulb hue is 90
dev:2332020-05-07 08:58:35.452 pm debugcolors: [255, 0, 153]
dev:2332020-05-07 08:58:35.434 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:blue, colorComponentId:4, value:153)
dev:2332020-05-07 08:58:35.423 pm debugparse:zw device: 10, command: 3304, payload: 04 99 , isMulticast: false
dev:2332020-05-07 08:58:35.362 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:35.352 pm infoDining Room Outdoor Light Bulb color is Magenta
dev:2332020-05-07 08:58:35.343 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:35.336 pm infoDining Room Outdoor Light Bulb hue is 83
dev:2332020-05-07 08:58:35.322 pm debugcolors: [255, 0, 255]
dev:2332020-05-07 08:58:35.313 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:green, colorComponentId:3, value:0)
dev:2332020-05-07 08:58:35.309 pm debugparse:zw device: 10, command: 3304, payload: 03 00 , isMulticast: false
dev:2332020-05-07 08:58:35.256 pm infoDining Room Outdoor Light Bulb was turned off
dev:2332020-05-07 08:58:35.247 pm debugSwitchMultilevelReport(value:0)
dev:2332020-05-07 08:58:35.242 pm debugparse:zw device: 10, command: 2603, payload: 00 , isMulticast: false
dev:2332020-05-07 08:58:32.096 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:32.088 pm infoDining Room Outdoor Light Bulb color is Magenta
dev:2332020-05-07 08:58:32.077 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:32.070 pm infoDining Room Outdoor Light Bulb hue is 83
dev:2332020-05-07 08:58:32.057 pm debugcolors: [255, 0, 255]
dev:2332020-05-07 08:58:32.048 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:red, colorComponentId:2, value:255)
dev:2332020-05-07 08:58:32.044 pm debugparse:zw device: 10, command: 3304, payload: 02 FF , isMulticast: false
dev:2332020-05-07 08:58:20.563 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:20.549 pm infoDining Room Outdoor Light Bulb color is Magenta
dev:2332020-05-07 08:58:20.515 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:20.466 pm infoDining Room Outdoor Light Bulb hue is 83
dev:2332020-05-07 08:58:20.453 pm debugcolors: [255, 0, 255]
dev:2332020-05-07 08:58:20.444 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:red, colorComponentId:2, value:255)
dev:2332020-05-07 08:58:20.441 pm debugparse:zw device: 10, command: 3304, payload: 02 FF , isMulticast: false
dev:2332020-05-07 08:58:20.293 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:20.257 pm infoDining Room Outdoor Light Bulb color is Magenta
dev:2332020-05-07 08:58:20.238 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:20.231 pm infoDining Room Outdoor Light Bulb hue is 83
dev:2332020-05-07 08:58:20.217 pm debugcolors: [255, 0, 255]
dev:2332020-05-07 08:58:20.205 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:red, colorComponentId:2, value:255)
dev:2332020-05-07 08:58:20.199 pm debugparse:zw device: 10, command: 3304, payload: 02 FF , isMulticast: false
dev:2332020-05-07 08:58:18.499 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:18.464 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:18.456 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:18.449 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:18.437 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:18.428 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:2332020-05-07 08:58:18.425 pm debugparse:zw device: 10, command: 3304, payload: 01 00 , isMulticast: false
dev:2332020-05-07 08:58:18.130 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:18.088 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:18.064 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:18.028 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:18.014 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:18.005 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0)
dev:2332020-05-07 08:58:18.001 pm debugparse:zw device: 10, command: 3304, payload: 00 00 , isMulticast: false
dev:2332020-05-07 08:58:17.639 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:17.615 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:17.605 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:17.594 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:17.582 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:17.573 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:2332020-05-07 08:58:17.570 pm debugparse:zw device: 10, command: 3304, payload: 01 00 , isMulticast: false
dev:2332020-05-07 08:58:11.288 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:11.264 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:11.235 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:11.225 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:11.174 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:11.154 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:2332020-05-07 08:58:11.150 pm debugparse:zw device: 10, command: 3304, payload: 01 00 , isMulticast: false
dev:2332020-05-07 08:58:11.063 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:11.043 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:11.008 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:10.980 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:10.946 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:10.920 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:2332020-05-07 08:58:10.911 pm debugparse:zw device: 10, command: 3304, payload: 01 00 , isMulticast: false
dev:2332020-05-07 08:58:10.837 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:10.811 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:10.798 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:10.777 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:10.744 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:10.730 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:2332020-05-07 08:58:10.722 pm debugparse:zw device: 10, command: 3304, payload: 01 00 , isMulticast: false
dev:2332020-05-07 08:58:07.573 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:07.496 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:07.453 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:07.436 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:07.363 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:07.332 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:2332020-05-07 08:58:07.328 pm debugparse:zw device: 10, command: 3304, payload: 01 00 , isMulticast: false
dev:2332020-05-07 08:58:07.293 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:07.278 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:07.268 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:07.257 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:07.245 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:07.221 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:2332020-05-07 08:58:07.218 pm debugparse:zw device: 10, command: 3304, payload: 01 00 , isMulticast: false
dev:2332020-05-07 08:58:05.352 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:05.342 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:05.334 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:05.326 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:05.314 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:05.303 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0)
dev:2332020-05-07 08:58:05.298 pm debugparse:zw device: 10, command: 3304, payload: 00 00 , isMulticast: false
dev:2332020-05-07 08:58:01.460 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:01.450 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:01.400 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:01.390 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:01.344 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:01.332 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0)
dev:2332020-05-07 08:58:01.328 pm debugparse:zw device: 10, command: 3304, payload: 00 00 , isMulticast: false
dev:2332020-05-07 08:58:01.272 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:58:01.259 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:58:01.246 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:58:01.236 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:58:01.222 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:58:01.213 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0)
dev:2332020-05-07 08:58:01.210 pm debugparse:zw device: 10, command: 3304, payload: 00 00 , isMulticast: false
dev:2332020-05-07 08:57:59.599 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:57:59.576 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:57:59.566 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:57:59.558 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:57:59.523 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:57:59.505 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0)
dev:2332020-05-07 08:57:59.500 pm debugparse:zw device: 10, command: 3304, payload: 00 00 , isMulticast: false
dev:2332020-05-07 08:57:59.220 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:57:59.204 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:57:59.174 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:57:59.166 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:57:59.154 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:57:59.144 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0)
dev:2332020-05-07 08:57:59.141 pm debugparse:zw device: 10, command: 3304, payload: 00 00 , isMulticast: false
dev:2332020-05-07 08:57:58.907 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:57:58.890 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:57:58.870 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:57:58.854 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:57:58.838 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:57:58.824 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0)
dev:2332020-05-07 08:57:58.821 pm debugparse:zw device: 10, command: 3304, payload: 00 00 , isMulticast: false
dev:2332020-05-07 08:57:57.887 pm infoDining Room Outdoor Light Bulb color mode is RGB
dev:2332020-05-07 08:57:57.857 pm debugr:255, g: 0, b: 153
dev:2332020-05-07 08:57:57.855 pm debugsetColor([saturation:100, hue:90, level:100])
dev:2332020-05-07 08:57:56.531 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:57:56.494 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:57:56.476 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:57:56.468 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:57:56.453 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:57:56.438 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0)
dev:2332020-05-07 08:57:56.433 pm debugparse:zw device: 10, command: 3304, payload: 00 00 , isMulticast: false
dev:2332020-05-07 08:57:56.219 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:57:56.191 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:57:56.162 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:57:56.152 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:57:56.109 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:57:56.086 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0)
dev:2332020-05-07 08:57:56.080 pm debugparse:zw device: 10, command: 3304, payload: 00 00 , isMulticast: false
dev:2332020-05-07 08:57:55.984 pm infoDining Room Outdoor Light Bulb level is 100
dev:2332020-05-07 08:57:55.975 pm infoDining Room Outdoor Light Bulb color is Violet
dev:2332020-05-07 08:57:55.966 pm infoDining Room Outdoor Light Bulb saturation is 100
dev:2332020-05-07 08:57:55.954 pm infoDining Room Outdoor Light Bulb hue is 74
dev:2332020-05-07 08:57:55.941 pm debugcolors: [112, 0, 255]
dev:2332020-05-07 08:57:55.931 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0)
dev:2332020-05-07 08:57:55.913 pm debugparse:zw device: 10, command: 3304, payload: 00 00 , isMulticast: false
dev:2332020-05-07 08:57:54.134 pm infoDining Room Outdoor Light Bulb color mode is RGB
dev:2332020-05-07 08:57:54.061 pm debugr:204, g: 255, b: 0
dev:2332020-05-07 08:57:54.055 pm debugsetColor([saturation:100, hue:20, level:100])
dev:2332020-05-07 08:57:50.985 pm infoDining Room Outdoor Light Bulb was set to 99%
dev:2332020-05-07 08:57:50.977 pm infoDining Room Outdoor Light Bulb was turned on
dev:2332020-05-07 08:57:50.969 pm debugSwitchMultilevelReport(value:99)
dev:2332020-05-07 08:57:50.954 pm debugparse:zw device: 10, command: 2603, payload: 63 , isMulticast: false
dev:2332020-05-07 08:57:46.039 pm debugparse:zw device: 10, command: 7006, payload: 02 01 01 , isMulticast: false
dev:2332020-05-07 08:57:44.912 pm warndebug logging is: true
dev:2332020-05-07 08:57:44.906 pm infoupdated...
Having an issue with these bulbs receiving a colour change command. Sending the command through MakerAPI and it just seems to go at random after receiving the first colour change command. Not sure if it's related to the driver or if it's on the other end but I figured I'd post up the log to get some input on it.
Is it intentional that you have 5 color changes here?
I’m making a bandwidth constrained (lower features) version today for people who have mesh issues. Until they update the firmware to support switch color CCv3 which will solve all of this
LOL Nope! Only trying to change it to Magenta.
Interesting.. It got 5 color changes from somewhere
Anyone experiencing bandwidth issues causing slow performance.. I just pushed an update that adds a low bandwidth mode that dramatically reduces packet count at the expense of colorTransition.
