Hi Bryan this app looks awesome! Could you also add door contacts? As I have a mighty mule hooked to a door contact to give me an alert, but could put a motion sensor out with it. Thanks again for all your great work!
I have installed your Driveway direction alerter and Follow Me. I probably have missed something, and am hoping you can help. This is the app description copied from the child app in Follow me.
Follow Me App (2.3.3) - Follow Me Child
Destination: Speakers Speaker Option: MediaPlayer: NA - SpeechSynthesis: [Basement TV Sonos, Office Sonos, Kitchen Sonos, Master Bedroom Sonos, Barn Sonos] - sonosSpeaker - Use Default: false Volume Options:
Speaker Volume: 60 - Quiet Time: false - Q Volume: NA - Q From: NA - Q To: NA - Q Midnight: NA
Speech Restriction: false - R From: NA - R To: NA - R Midnight: NA Message Priority: false - priorityVoices: NA - messageSounds: NA
it isn't doing anything. I thought I may have messed up setting up the Follow me. In DA, I set up the two contact closures and use the Follow me as the speaker. I will see what the logs say.
So I looked at the logs since I went out to run an errand and just came back. It shows the one contact opening and closing, but not the other. I will check that out first and see if that helps.
