[Deprecated] CATT Director (App and Driver)
Wondering if you've had a chance to look at this?
I have not, sorry
No problem!
Had a closer look at the CATT command set. Speech does not appear to be an option in CATT but it appears in the command section of your driver because of the inclusion of 'speech synthesis' in the driver.
Thanks for making this happen. I just picked up a Google Nest Hub for 50$ at walmart. I am guessing there is no way to make casting a dashboard and music play at the same time?
I am hoping to run my dashboard 24/7
Tried searching through all the documentation but still not able to get it running on a windows server. Have CATT installed and everything running. I can ping the telnet port 23 on the server from another computer. I can even use powershell to cast to the hub directly from the server. But using hubitat the CATT server device hangs on telnet:opening and nothing else happens. Quadruple checked all settings.
Seems like this thread is mostly dead, so if anyone else is having similar issues I got it working on a Windows server using eventghost by having it execute the CATT command on the server directly using [PORT] - Send Events to EventGhost
CATT director still works for me (CATT server on a raspberry pi) but I also cast via Node red (essentially this is same approach to what you are doing). If the app breaks at some point (I assume it shouldn't as it is just SSHing into the CATT server and executing the CATT commands) I'll move what's left into NR.
