Command1
Wait 2secs
Command2
Wait 5secs
Command 3
Wait 1 sec
Command 4
I know this is probably really simple but I’ve tried everything my novice mind could think of and I can’t get this to work. How do I accomplish this?
Command1
Wait 2secs
Command2
Wait 5secs
Command 3
Wait 1 sec
Command 4
delayBetween(cmdList,ms)
I would need a different delay between each command.
not necessarily. You could put a bunch of null commands in that would eat up a 1 sec delay each for now, until a better option came along.
You could use three runIns…
Or pauseExecution(Long milliseconds)
I tried runIns but it would only seem to execute when each command was different. What I’m really trying to do is run the same command with a different parameter each time.
Thanks for the suggestions. I will try the null commands and pauseExecutions to see if I get better luck. If you have any other tricks I’m all ears.
def cmds = [
Command1,
"delay 2000",
Command2,
"delay 5000",
Command3,
"delay 4000",
Command4
So...like everything I've tried so far...it doesn't quite work. It runs but all the commands execute with no delay. Arrrgg...What am I doing wrong? See the dth code below...the string of commands is in the runSequence method.
* HTTP Momentary Switch
* Copyright 2018 Daniel Ogorchock
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Change History:
* Date Who What
* 2018-02-18 Dan Ogorchock Original Creation
metadata {
definition (name: "HTTP Momentary Switch Sequencer", namespace: "ogiewon", author: "Dan Ogorchock") {
capability "Switch"
capability "Momentary"
command "RunSequence", ["number"]
preferences {
input(name: "deviceIP", type: "string", title:"Device IP Address", description: "Enter IP Address of your HTTP server", required: true, displayDuringSetup: true, submitOnChange: true)
input(name: "devicePort", type: "string", title:"Device Port", description: "Enter Port of your HTTP server (defaults to 80)", defaultValue: "80", required: false, displayDuringSetup: true, submitOnChange: true)
input(name: "deviceMethod", type: "enum", title: "POST, GET, or PUT", options: ["POST","GET","PUT"], defaultValue: "POST", required: true, displayDuringSetup: true, submitOnChange: true)
input "hub", "enum", title: "Select Hub", required: false, displayDuringSetup: true, options: getFromApi("hub"), submitOnChange: true
input "activities", "enum", title: "Select Activity", required: false, displayDuringSetup: true, options: getFromApi("activities"), submitOnChange: true
//input(name: "devicePath", type: "string", title:"URL Path", description: "Rest of the URL, include forward slash.", displayDuringSetup: true)
getCommands()
private getOptionsInput(item) {
input "${item}", "enum",
title: "Select ${item}",
//defaultValue: "none",
required: false,
options: getFromApi(item)
def getCommands(){
for(i in 1..10) {
input "deviceCommand${i}", "enum", description: "", title: "Command ${i}", displayDuringSetup: true, options: getFromApi("commands")
def getFromApi(item){
def myOptions
def myPath = ""
def myServer = ""
if(deviceIP) myServer = "http://${deviceIP}:${devicePort}"
//log.debug myServer
if(item=="hub") myPath = "/hubs"
if(item=="activities") myPath = "/hubs/${hub}/activities"
if(item=="commands") myPath = "/hubs/${hub}/commands"
//log.error myPath
def params = [
uri: myServer,
path: myPath
try {
httpGet(params) { resp ->
resp.headers.each {
//log.debug "${it.name} : ${it.value}"
//log.debug "response contentType: ${resp.contentType}"
//log.debug "response data: ${resp.data}"
if(item=="hub") myOptions = resp.data.hubs
if(item=="activities") myOptions = resp.data.activities.slug
if(item=="commands") myOptions = resp.data.commands.slug
//log.error list
} catch (e) {
log.error "something went wrong: $e"
//log.debug list.hubs.size
return myOptions
log.debug(description)
def push() {
//toggle the switch to generate events for anything that is subscribed
sendEvent(name: "switch", value: "on", isStateChange: true)
runIn(1, toggleOff)
//sendEvent(name: "switch", value: "off", isStateChange: true)
def newPath = "/hubs/"+hub+"/activities/"+activities
runCmd(newPath, deviceMethod)
def on() {
push()
def off() {
//push()
def newPath = "/hubs/"+hub+"/off"
runCmd(newPath, "PUT")
def toggleOff() {
def RunSequence(num) {
log.info num
def path = "/hubs/"+hub+"/commands/"+settings["deviceCommand${num}"]
log.info path
//runSeq(path, deviceMethod)
def cmds = [
runSeq("/hubs/"+hub+"/commands/"+settings["deviceCommand1"],deviceMethod),
"delay 2000",
runSeq("/hubs/"+hub+"/commands/"+settings["deviceCommand2"],deviceMethod),
"delay 5000",
runSeq("/hubs/"+hub+"/commands/"+settings["deviceCommand3"],deviceMethod),
"delay 4000",
runSeq("/hubs/"+hub+"/commands/"+settings["deviceCommand4"],deviceMethod),
return cmds
def runSeq(varCommand,method){
def localDevicePort = (devicePort==null) ? "80" : devicePort
//def path = varCommand
//def meth = method
def body = ""
def headers = [:]
headers.put("HOST", "${deviceIP}:${localDevicePort}")
headers.put("Content-Type", "application/x-www-form-urlencoded")
try {
def hubAction = new hubitat.device.HubAction(
method: method,
path: varCommand,
body: body,
headers: headers
log.debug hubAction
return hubAction
catch (Exception e) {
log.debug "runCmd hit exception ${e} on ${hubAction}"
def runCmd(String varCommand, String method) {
def body = ""
def headers = [:]
try {
method: method,
path: path,
body: body,
headers: headers
log.debug hubAction
return hubAction
I think I see the issue, the delay command only works on zigbee and z-wave commands.
You want to delay the hubaction for a lan request. You probably should look at using runIn() as a way to schedule each request.
I initially tried the runIn() but it wouldn’t execute all the commands. If I created a different method for each command it would run, but since I’m using the same method with different parameters, it would not process all the commands…just the first. I can revert to that method and post the code alongside the logs if that will help diagnose.
It may be a limit of how we process functions containing a hubaction. I’ll set up a test over the weekend.
If you got it working with sub functions I’d go with that and just pass the params to that sub function.
So hopefully I can explain this without confusing everyone. Looking at the code below…
def runSequence(){
runIn(3,"runTest1",[data: [num: 1]])
runIn(6,"runTest1",[data: [num: 2]])
def runTest1(data) {
log.info data.num
def path = "/hubs/"+hub+"/commands/"+settings["deviceCommand${data.num}"]
log.info path
def runTest2(data) {
log.info data.num
log.info path
//def meth = method
def body = ""
def headers = [:]
try {
method: method,
path: varCommand,
body: body,
headers: headers
log.debug hubAction
return hubAction
runTest1() and runTest2() are identical
If I code runSequence() to use the same method with a different parameter, it olny executes the second command.
If I code runSequence() to 2 separate methods (with the exact same code in both) it will then execute both commands.
eg.
def runSequence(){
runIn(6,"runTest2",[data: [num: 2]])
I could create a separate method for each line, but this would be FAR from ideal since in at least one case, I will be executes about 10 commands.
I believe something like the following should work, but if it has the same rate limits as SmartThings you can only have 4 scheduled at the same time.
def runSequence(){
runIn(3,"runTest",[overwrite: false, data: [num: 1]])
runIn(6,"runTest",[overwirte: false, data: [num: 2]])
Mike and/or Chuck,
I am trying to understand whether or not Hubitat supports the old SmartThings "pause(milliseconds)" command or not? If not, what is a suitable replacement? I have tried "sleep(milliseconds)" and "thread.sleep(milliseconds)", but both are rejected by Hubitat as Not Allowed.
Mike mentions "pauseExecution(seconds)" above. Is that a valid call? If so, is it really seconds? I need something that can handle milliseconds. As I am only looking to delay for about 250ms.
Thanks,
Dan
sorry, pauseExecution(Long milliseconds), I’ll correct that post…
Thanks Mike! I’ll give that a try.
