I just received and installed my HE Hub and the portal (portal[dot]hubitat[dot]com) will not detect my hub.
Info:
-New C5 Hub (USA)
-My PC and HE Hub are on the same LAN.
-The HE Hub has been on and connected to the LAN for at least 30 minutes.
-I'm using oAuth to login to the portal.
-Portal allows me to login and gives me this:
If I right-click "Hubs" at the top of the page and open in a new tab I get this:
On this screen, If I click on "Login" or "Register" I'm prompted to sign in using email and password (NOT oAuth).
If I log-in here then I'm returned to a screen that's exactly like the first picture.
Can you connect to the Hubitat Hub via its IP address in your browser? (Look in your routerโs dhcp assignments list to find the IP addresss for the Hubโs MAC address found on the bottom of the hub.)
I've only ever used oAuth. No multiple accounts. JavaScript is not blocked. I am seeing some funny device information on my router device list. I do see the HE and my PC on the router but I still can't connect to the HE IP address. There's other devices connected to my network that aren't showing on my router so I'm going to see if there's any firmware updates for my router and switch first and then re-boot.
FIXED! I updated the firmware on my router and now I can see the HE Hub. I'll browse through the router firmware update notes later but there's a bullet point for an IPV6 bug that probably caused this issue. I am up and running now. Thanks again HE family!
