DateTime variable formatting
Is there a way that I can get sunrise and sunset times without the date in a log entry? Here's the rule and you can see by the values that the log has the date. Thanks!
I use the hub information driver to do this. My hub variables are strings, which may not work for you depending on what you want to do with them, I just display them on a dashboard.
Thanks! I found what I needed - a function of Set Variable is Erase Date - Wahoo!
