I have seen these errors recently in my C-4 logs for various devices, however the devices continue to work after the logs appeared. Most recently I saw them between 3:30 - 4am this morning. I have seen in other Community posts people talk about this being a sign of a potential database corruption and to do a soft reset and db restore. I had to do this (db restore only) recently on my C-7 hub after seeing a 500 error in the Web UI.
Connections could not be acquired from the underlying database
Should I be worried? Should I do the reset and restore?
@bobbyD - Out of interest.... Separate to my C-4 hub which this post related to, I mentioned getting the 500 error on my C-7 hub a few days ago and needing to restore the db on that hub as well. I saw a somewhat similar error in the C-7's logs just before that incident, could this have also been a corruption?
java.lang.RuntimeException: java.sql.SQLException: A problem occurred while trying to acquire a cached PreparedStatement in a background thread. Query: UPDATE DEVICE D SET D.STATE = ? WHERE D.ID = ? Parameters: [{"lastBattery":1625018716,"tempOffset":0,"sensorTemp":18.78}, 8] (parse)
