Data between 2 C8s on different public IP addresses
What is the best way share data between 2 C8s on different public IP addresses
Example, if I have C8 in Texas, and I need to share data to another C8 in Louisiana, and share data in reverse order
Thanks in advance
Depends on the data. What are you wanting to share?
HubConnect
It will work by using Hubitat's cloud as a "connector". The original developer created it so he could have a Hub in his RV traveling around the country using whatever internet he found at various campsites.
Either setup a VPN to the other site or use Hubitat's Remote Admin to be able to setup the App on both ends.
https://hubconnect.hubitatcommunity.com/
I just want to share a device between two hubs. Basically what I need is when an alarm triggers on say hub1/device1, I want to send that status/alarm to hub2 to energize a relay on hub2,, then reverse order, When hub2/device 2 triggers, t want to send that status/alarm to hub1 to energize a relay on hub1
In the SCADA world, its called mirror IO (inputs/ouputs), sharing IO between two location, (a virtual wire extender using communication)
Then you'll want to look at the Hub Connect app @csteele mentioned above.
cool, thanks
