Is there anyway to make a tile that points to and opens an app on a phone/device?
Yes if you have an Android phone. You will need to have an app called tasker installed together with a couple of plugins. This link should give you some ideas Tasker Trigger, @sburke781 would be able to provide some guidance as I don't do much with tasker these days.
Like @rocketwiz described, Tasker would be one option, MacroDroid may be another. You may be able to initiate the app directly on the device, but I'm not 100% sure of how to do it, if it is possible.
There may be local options with Tasker and one or two of it's plugins, but the one I would feel most comfortable guiding you through would be something like:
- Install and configure Tasker and AutoRemote plugin (there's a few steps to go through with this part, hopefully you can find enough online)
- Make sure your phone / device has a fixed IP on your local network
- Create a Virtual Button device on HE
- Add the button device to the dashboard, including setting up a tile
- Create a rule, e.g. RM Rule, triggered by the pressing of the button
- For the actions in the rule, make a HTTP GET call to your phone, with something like:
http://< Phone IP >:1817/?message=NetFlix- Replace the
< Phone IP >with the IP Address of your phone andNetFlixwith whatever text you like at this stage
I might need to come back with part two of these instructions....
Maybe later this evening or tomorrow. But if you are proficient in Tasker, you want to create a profile triggered by an event from a plugin, being AutoRemote, filtering on a message with the text you put in place of NetFlix above. Then add an action to open an app of your choosing. Don't worry, I can guide you through this part later if needed, or someone else...
I'm also working on a Tasker integration to make some of this stuff a little easier, so this post gave me some ideas or at least inspiration to include something like this. I just haven't added it to the list yet...
There's also the autolaunch plugin which is able to launch apps directly but I have not bought this one so YMMV.
Thanks guys I'll check it out. Also found this dashboard app called HomeHabit that looks pretty good
If you use Fully Kiosk browser, you can use the intent links in coordination with their app launcher.
Used with action tiles on ST many years ago....
