Dashboard clock system time option
It would be nice if there was a system time option for the clock dashboard tile. While traveling internationally it would be nice to have a clock tile to look at to see what time it is currently at home. Right now the clock tile must use the browsers time at the time of loading the dashboard so it showed the international time on the dashboard.
Hi @Terk, something like this?
I am using the NTP device driver and added a tile for the NTP device using date & clock. Other options are clock only and date only.
Actually these tiles can be created based on almost any device and then selecting the desired attribute in the right hand column.
You could also look at a driver I wrote originally and @luarmr updated to include the timezone selection. But yes, would be nice if it was built-in.
Just realized my comment at the top of that page to also consider @jshimota 's driver as well
I should be able to add an NTP server to the OpenVPN router at that location to try that hopefully in the next few days.
@Terk
I used this one directly on the Hubitat
Hope that works for you
The Date Time Parser doesn't format the way I want with it all on one tile. Your driver works well though. Thanks.
All kudo’s go to @dan.t for this one!
