Hi
I am trying to get my danalock to run reliable. I'm currently experiencing that when i manually lock/Unlock the door the status will not be sent to hubitat. I also using danalocks BLE pad and when i unlock/ lock the door again the status will not be sent to hubitat.
There are specific Danalock drivers? I'm just using the generic zigbee lock driver which also has the same problem mentioned above but not all the time.
I can't find the specific Danalock driver in the list. I'm on 2.2.8.156 but a check for updates does not show any. Are the Danalock drivers new to 2.2.9 and if so I presume this is still in beta?
I have a Zemismart Zigbee roller shade. I can confirm that it works with Google Home. I just linked it via the Google Home app in Hubitat and was able to control it.
Would it be possible to add "auto calibration" action for Danalock ?
Sometimes my lock loses calibration and it is nly fixed by doing a calibration.
When I am close to the lock, it is not a problem, but sometimes I have to unlock the door for my kid and if the calibration problem occurs at that time, we end up without a solution and he has to wait for me to arrive home.
So if there is a way to trigger auto calibration remotely, it would help a lot.
I have a mail conversation with Danalock right now where they want to look into the issue that the lock looses its calibration.
They have requested (and I have sent) information and film clips.
Hopefully they can find a fix for it and we don’t need to trigger a scheduled automatic calibration.
actually a few years ago, I had my first Danalock and it had this calibration issue awfully. I had to calibrate it everyday. Then I contacted support and they sent me a new lock.
So I had thought that it was a known issue and some locks had this problem.
My replacement lock didn't have the issue as bad as the first one.
I just have to recalibrate once every week.
I don't think that Danalock will have a software based solution for this. Although they should. (I believe it can be solved with a software solution which would recalibrate automatically)
They might replce your lock.
In any case, if they provide a soluiton , please let me know.
I have several of the V3 Zigbee locks. I am using the Generic Zigbee Lock as I don’t see a Zigbee built in driver, just a Zwave. However, I never have to recalibrate the locks, but the do fall off the mesh occasionally.
