Hi all. I have a custom app called home cloud hub which was ported over from SmartThings. It was working perfectly until I updated the hub firmware. If I go into the device and push any button the device never changes and nothing is ever logged within Hubitat.
I've tried to create the device again, but it still does not work. If I change the device to a Hubitat Default Virtual Switch Driver on and off works fine.
I do see other attributes being updated in the device events, but On and Off do not ever update. I can change dimmer level, however.
Does anyone have ideas on what the problem could be?
Here is the code:
* AT&T Digital Life System
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Version history
* v0.1.08.12.18 - Ported to hubitat. commented out smartThings specific items.
* v0.1.04.06.16 - Removed Location Mode capability - might interfere with Rule Machine
* v0.1.03.24.16 - Published device as switch to allow easy manipulation via rules - on() sets it to away
* and off() sets it to home. Also published commands setMode(mode), home(), away(), stay().
* You can now also use it as a "Switch Level" by setting the level to 0 for home, 1 for stay
* and 2 or more for away.
* v0.1.03.22.16 - Initial beta release
metadata {
definition (name: "AT&T Digital Life System", namespace: "Keo", author: "Joe Rosiak", oauth: true) {
capability "Actuator"
capability "Refresh"
capability "Configuration"
capability "Switch"
capability "Switch Level"
attribute "digital-life-mode", "enum", ["Home", "Stay", "Instant", "Away"]
attribute "id", "string"
attribute "module", "string"
attribute "type", "string"
attribute "system-status", "enum", ["Home", "Home Bypass", "Home ExitDelay", "Stay", "Stay AlarmPending", "Away", "Away AlarmPending", "Instant", "Instant AlarmPending"]
attribute "arm-state", "string"
attribute "alarm-mode", "string"
attribute "bypassed-device-list", "string"
attribute "alarmed-device-list", "string"
attribute "armed-stay-device-list", "string"
attribute "armed-away-device-list", "string"
attribute "armed-instant-device-list", "string"
attribute "alarm-timeout", "number"
attribute "entry-delay", "number"
attribute "exit-delay", "number"
attribute "abort-timeout", "number"
command "home"
command "stay"
command "away"
command "setMode"
command "describeAttributes"
// parse events into attributes
def describeAttributes(payload) {
payload.attributes = [
[ name: "system-status", type: "enum", options: ["Home", "Home Bypass", "Home ExitDelay", "Stay", "Stay AlarmPending", "Away", "Away AlarmPending", "Instant", "Instant AlarmPending"] ],
[ name: "digital-life-mode", type: "enum", options: ["Home", "Stay", "Instant", "Away"] ],
return null
def configure(mode) {
setMode(mode)
def setLevel(level) {
if (level < 0) {
level = 0
if (level > 3) {
level = 3
switch (level) {
case 0:
home()
break
case 1:
stay()
break
case 2:
instant()
break
default:
away()
break
def setMode(mode) {
switch (mode.toLowerCase()) {
case 'home':
case 'disarm':
case 'disarmed':
case 'off':
home()
break
case 'stay':
case 'night':
stay()
break
case 'instant':
instant()
break
case 'away':
away()
break
def on() {
stay()
def off() {
home()
def home() {
parent.proxyCommand(device, 'digital-life-mode', 'Home');
def stay() {
parent.proxyCommand(device, 'digital-life-mode', 'Stay');
def instant() {
parent.proxyCommand(device, 'digital-life-mode', 'Instant');
def away() {
parent.proxyCommand(device, 'digital-life-mode', 'Away');
