Thanks for the help from @holand.ivar now I have a Custom Driver for
my Tuya Vertical Blinds and integration is 100% local.
Driver works but has some abnormal behavior. Of course, I was talking
to the author of this driver but he is confused why driver exhibits some
abnormal behavior. I really would like if not fix the driver but at least to
understand what is going on. So, I decided to ask driver gurus on a forum
for a help.
Here is a driver code:
* Copyright 2022 Ivar Holand
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
metadata {
definition(name: "Tuya Generic Window Blind", namespace: "iholand", author: "iholand") {
capability "Actuator"
capability "Sensor"
capability "WindowBlind"
// capability "WindowShade"
command "status"
attribute "availableEndpoints", "String"
preferences {
section("URIs") {
input "ipaddress", "text", title: "Device IP:", required: false
input "devId", "text", title: "Device ID:", required: false
input "localKey", "text", title: "Device local key:", required: false
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input "tuyaProtVersion", "enum", title: "Select tuya protocol version: ", required: true, options: [31: "3.1", 33 : "3.3"]
def logsOff() {
log.warn "debug logging disabled..."
device.updateSetting("logEnable", [value: "false", type: "bool"])
def updated() {
log.info "updated..."
log.warn "debug logging is: ${logEnable == true}"
if (logEnable) runIn(1800, logsOff)
sendEvent(name: "switch", value: "off")
if (logEnable) log.debug "Receiving message from device"
if (logEnable) log.debug(description)
byte[] msg_byte = hubitat.helper.HexUtils.hexStringToByteArray(description)
String status = new String(msg_byte, "UTF-8")
String protocol_version = ""
status = status[20..-1]
if (logEnable) log.debug "Raw incoming data: " + status
if (!status.startsWith("{")) {
// Encrypted message incoming, decrypt first
if (logEnable) log.debug "Encrypted message detected"
if (logEnable) log.debug "Bytes incoming: " + msg_byte.size()
def message_start = 0
// Find message type to determine start of message
def message_type = msg_byte[11].toInteger()
if (message_type == 7) {
// Incoming control message
// Find protocol version
byte[] ver_bytes = [msg_byte[48], msg_byte[49], msg_byte[50]]
protocol_version = new String(ver_bytes)
if (protocol_version == "3.1") {
message_start = 67
} else if (protocol_version == "3.3") {
message_start = 63
} else if (message_type == 10) {
// Incoming status message
message_start = 20
// Status messages do not contain version information, however v 3.3
// protocol encrypts status messages, v 3.1 does not
protocol_version = "3.3"
// Find end of message by looking for 0xAA55
def end_of_message = 0
for (u = message_start; u < msg_byte.size()-1; u++) {
if (msg_byte[u] == (byte)0xAA && msg_byte[u+1] == (byte)0x55) {
//msg end found
if (logEnable) log.debug "End of message: ${u-message_start-6}"
end_of_message = u-message_start-6
break
// Re-assemble the bytes for decoding
ByteArrayOutputStream output = new ByteArrayOutputStream()
for (i = message_start; i < end_of_message+message_start; i++) {
output.write(msg_byte[i])
byte[] payload = output.toByteArray()
if (logEnable) log.debug "Assembled payload for decrypt: "+ hubitat.helper.HexUtils.byteArrayToHexString(payload)
def dec_status = ""
dec_status = decrypt_bytes(payload, settings.localKey, true)
dec_status = decrypt_bytes(payload, settings.localKey, false)
if (logEnable) log.debug "Decryted message: ${dec_status}"
status = dec_status
parse_tuya_payload(status)
try {
interfaces.rawSocket.close()
} catch (e) {
log.error "Could not close socket: $e"
def parse_tuya_payload(status) {
def jsonSlurper = new groovy.json.JsonSlurper()
def status_object = jsonSlurper.parseText(status)
sendEvent(name: "availableEndpoints", value: status_object.dps)
if (status_object.dps["1"] == "open") {
sendEvent(name: "windowBlind", value : "open")
} else if (status_object.dps["1"] == "close") {
sendEvent(name: "windowBlind", value : "closed")
if (status_object.dps["2"]) {
sendEvent(name: "tilt", value : status_object.dps["2"])
if (status_object.dps["3"]) {
sendEvent(name: "position", value : status_object.dps["3"])
def status() {
send(generate_payload("status"))
def open() {
send(generate_payload("set", ["1":"open"]))
// Testing
/*parse_tuya_payload("{\"devId\":\"2502206124a160295f27\",\"dps\":{\"1\":\"open\",\"2\":100,\"3\":98}}")
parse_tuya_payload("{\"devId\":\"2502206124a160295f27\",\"dps\":{\"3\":40}}")
parse_tuya_payload("{\"devId\":\"2502206124a160295f27\",\"dps\":{\"1\":\"close\"}")*/
def close() {
send(generate_payload("set", ["1":"close"]))
def setPosition(position) {
send(generate_payload("set", ["3":position]))
def setTiltLevel(tilt) {
send(generate_payload("set", ["2":tilt]))
def startPositionChange(direction) {
if (direction == "open") {
open()
} else if (direction == "close") {
close()
def stopPositionChange() {
send(generate_payload("set", ["1":"stop"]))
import hubitat.device.HubAction
import hubitat.device.Protocol
def send(byte[] message) {
String msg = hubitat.helper.HexUtils.byteArrayToHexString(message)
if (logEnable) log.debug "Sending message to " + settings.ipaddress + ":" + 6668 + " msg: " + msg
try {
//port 6668
interfaces.rawSocket.connect(settings.ipaddress, 6668, byteInterface: true, readDelay: 500)
interfaces.rawSocket.sendMessage(msg)
} catch (e) {
log.error "Error $e"
def generate_payload(command, data=null) {
def json = new groovy.json.JsonBuilder()
json_data = payload()["device"][command]["command"]
if (json_data.containsKey("gwId")) {
json_data["gwId"] = settings.devId
if (json_data.containsKey("devId")) {
json_data["devId"] = settings.devId
if (json_data.containsKey("uid")) {
json_data["uid"] = settings.devId
if (json_data.containsKey("t")) {
Date now = new Date()
json_data["t"] = (now.getTime()/1000).toInteger().toString()
//json_data["t"] = "1602184793" // for testing
if (data != null) {
json_data["dps"] = data
json json_data
if (logEnable) log.debug tuyaProtVersion
json_payload = groovy.json.JsonOutput.toJson(json.toString())
json_payload = json_payload.replaceAll("\\\\", "")
json_payload = json_payload.replaceFirst("\"", "")
json_payload = json_payload[0..-2]
if (logEnable) log.debug "payload before=" + json_payload
if (command == "set" && tuyaProtVersion == "31") {
encrypted_payload = encrypt(json_payload, settings.localKey)
if (logEnable) log.debug "Encrypted payload: " + hubitat.helper.HexUtils.byteArrayToHexString(encrypted_payload.getBytes())
preMd5String = "data=" + encrypted_payload + "||lpv=" + "3.1" + "||" + settings.localKey
if (logEnable) log.debug "preMd5String" + preMd5String
hexdigest = generateMD5(preMd5String)
hexdig = new String(hexdigest[8..-9].getBytes("UTF-8"), "ISO-8859-1")
json_payload = "3.1" + hexdig + encrypted_payload
} else if (tuyaProtVersion == "33") {
encrypted_payload = encrypt(json_payload, settings.localKey, false)
if (logEnable) log.debug encrypted_payload
if (command != "status" && command != "12") {
output.write("3.3".getBytes())
output.write("\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000".getBytes())
output.write(hubitat.helper.HexUtils.hexStringToByteArray(encrypted_payload))
} else {
if (tuyaProtVersion == "31") {
output.write(json_payload.getBytes())
if (logEnable) log.debug "payload after=" + json_payload
output.write(hubitat.helper.HexUtils.hexStringToByteArray(payload()["device"]["suffix"]))
byte[] bff = output.toByteArray()
if (logEnable) log.debug hubitat.helper.HexUtils.byteArrayToHexString(bff)
postfix_payload = bff
postfix_payload_hex_len = postfix_payload.size()
if (logEnable) log.debug postfix_payload_hex_len
if (logEnable) log.debug "Prefix: " + hubitat.helper.HexUtils.byteArrayToHexString(hubitat.helper.HexUtils.hexStringToByteArray(payload()["device"]["prefix"]))
output = new ByteArrayOutputStream();
output.write(hubitat.helper.HexUtils.hexStringToByteArray(payload()["device"]["prefix"]))
output.write(hubitat.helper.HexUtils.hexStringToByteArray(payload()["device"][command]["hexByte"]))
output.write(hubitat.helper.HexUtils.hexStringToByteArray("000000"))
output.write(postfix_payload_hex_len)
output.write(postfix_payload)
byte[] buf = output.toByteArray()
crc32 = CRC32b(buf, buf.size()-8) & 0xffffffff
if (logEnable) log.debug buf.size()
hex_crc = Long.toHexString(crc32)
if (logEnable) log.debug "HEX crc: $hex_crc : " + hex_crc.size()/2
// Pad the CRC in case highest byte is 0
if (hex_crc.size() < 7) {
hex_crc = "00" + hex_crc
crc_bytes = hubitat.helper.HexUtils.hexStringToByteArray(hex_crc)
buf[buf.size()-8] = crc_bytes[0]
buf[buf.size()-7] = crc_bytes[1]
buf[buf.size()-6] = crc_bytes[2]
buf[buf.size()-5] = crc_bytes[3]
return buf
// Helper functions
def payload()
def payload_dict = [
"device": [
"status": [
"hexByte": "0a",
"command": ["devId": "", "gwId": "", "uid":"", "t": ""]
"set": [
"hexByte": "07",
"command": ["devId":"", "uid": "", "t": ""]
"prefix": "000055aa00000000000000",
"suffix": "000000000000aa55"
return payload_dict
// Huge thank you to MrYutz for posting Groovy AES ecryption drivers for groovy
//https://community.hubitat.com/t/groovy-aes-encryption-driver/31556
import javax.crypto.spec.SecretKeySpec;
import javax.crypto.spec.IvParameterSpec;
import javax.crypto.Cipher
// Encrypt plain text v. 3.1 uses base64 encoding, while 3.3 does not
def encrypt (def plainText, def secret, encodeB64=true) {
// Encryption is AES in ECB mode, pad using PKCS5Padding as needed
def cipher = Cipher.getInstance("AES/ECB/PKCS5Padding ")
SecretKeySpec key = new SecretKeySpec(secret.getBytes("UTF-8"), "AES")
// Give the encryption engine the encryption key
cipher.init(Cipher.ENCRYPT_MODE, key)
def result = ""
if (encodeB64) {
result = cipher.doFinal(plainText.getBytes("UTF-8")).encodeBase64().toString()
} else {
result = cipher.doFinal(plainText.getBytes("UTF-8")).encodeHex().toString()
return result
// Decrypt ByteArray
def decrypt_bytes (byte[] cypherBytes, def secret, decodeB64=false) {
if (logEnable) log.debug "*********** Decrypting **************"
SecretKeySpec key = new SecretKeySpec(secret.getBytes(), "AES")
cipher.init(Cipher.DECRYPT_MODE, key)
if (decodeB64) {
cypherBytes = cypherBytes.decodeBase64()
def result = cipher.doFinal(cypherBytes)
return new String(result, "UTF-8")
import java.security.MessageDigest
def generateMD5(String s){
MessageDigest.getInstance("MD5").digest(s.bytes).encodeHex().toString()
def CRC32b(bytes, length) {
crc = 0xFFFFFFFF
for (i = 0; i < length; i++) {
b = Byte.toUnsignedInt(bytes[i])
crc = crc ^ b
for (j = 7; j >= 0; j--) {
mask = -(crc & 1)
crc = (crc >> 1) ^(0xEDB88320 & mask)
return ~crc
Just in case, here is extracted Device Commands/Status structure:
Response
"result": {
"category": "cl",
"functions": [
"code": "control",
"lang_config": {
"close": "Close",
"open": "Open",
"stop": "Stop"
"name": "Control",
"type": "Enum",
"values": "{\"range\":[\"open\",\"stop\",\"close\"]}"
"code": "percent_control",
"lang_config": {
"unit": "%"
"name": "Curtain position setting",
"type": "Integer",
"values": "{\"unit\":\"%\",\"min\":0,\"max\":100,\"scale\":0,\"step\":1}"
"code": "mode",
"lang_config": {
"morning": "Morning Mode",
"night": "Night Mode"
"name": "Mode",
"type": "Enum",
"values": "{\"range\":[\"morning\",\"night\"]}"
"status": [
"code": "control",
"lang_config": {
"close": "Close",
"open": "Open",
"stop": "Stop"
"name": "Control",
"type": "Enum",
"lang_config": {
"unit": "%"
"type": "Integer",
"code": "percent_state",
"lang_config": {
"unit": "%"
"name": "Current curtain position",
"type": "Integer",
"code": "mode",
"lang_config": {
"name": "Mode",
"type": "Enum",
"code": "work_state",
"lang_config": {
"closing": "Closing",
"opening": "Opening"
"name": "Work State",
"type": "Enum",
"values": "{\"range\":[\"opening\",\"closing\"]}"
"code": "time_total",
"lang_config": {
"unit": "ms"
"name": "Total Time",
"type": "Integer",
"values": "{\"unit\":\"ms\",\"min\":0,\"max\":120000,\"scale\":0,\"step\":1}"
"code": "situation_set",
"lang_config": {
"fully_close": "Fully close",
"fully_open": "Fully open"
"name": "Situation_set",
"type": "Enum",
"values": "{\"range\":[\"fully_open\",\"fully_close\"]}"
"success": true,
"t": 1667927367503,
"tid": "19f68e325f8811ed8475060dd053b58c"
And here is a Device Driver page:
All buttons on the Device Diver page are 100% functional except for the
"Set Position" button. This function is not supported (I think) by the device.
Device does not report Status by itself but always updates Status in a
response for the "Status Report" command.
Here is my Test Rule:
Here is a first abnormality.
I think, it should not be difference how command is generated from RM
But this I mean command could be created as a "Command" and/or "Custom Command"
(please check first 2 lines in my test rule above).
If I am using "Close" command from RM (first line , now commented out) nothing is
happening with physical device and log always produces an error:
But if I am using close() custom attribute command everything is working just fine.
Also "Close" button from the Device Driver page also is working without any problems.
What is wrong with this picture?
Second abnormality is:
I was not able to use open/closed status in RM rule.
My "While Loop" periodically sends a "Status" command. On the Device Driver page
status is updated accordingly but RM never can detect an updated open/closed status.
If I am using "Position" value as n open/closed detection the RM rule can see it
just fine and everything is working as it should.
Again, what is wrong with this picture?
I hope, driver experts can spot something in the driver code.
Thank you in advance.
And just in case, here is my final rule which works just fine:
open/close status check done a bit different from it was in my test rule.
PS.
All testing and debugging was done on my spare C-5 with latest 2.3.3.140 SW
but actual working version is on my work horse C-7 also with latest 2.3.3.140 SW
I think, this should not matter.
