Hi All,
Trying to figure out how to make a dashboard tile with multiple attributes. Case in point - I have a number of keen registers and need the to display "level" as well as battery % on the same tile. Is this possible?
Assuming there isn't a template that would display both, don't have any registers so just asking.
One option is TileMaster, great app that can combine multiple attributes into one dashboard tile.
Alternatively, you can overlay two tiles on the dashboard and use some creative CSS coding to give it the desired look. You situation might be a little more complicated but an example, I have Halo Smoke Detectors that can be displayed as smoke or CO detectors using the built-in templates. Below is two tiles, overlayed to be the size of one. Smoke on left/CO on the right
CSS
/*Left*/
#tile-7 .tile-primary {
display:block;
position:relative;
width:50%;
top:33%;
/*Right*/
#tile-8 {
border-left:none;
background:transparent !important
#tile-8 .tile-primary {
display:block;
position:relative;
left:33%;
top:33%
#tile-8 .tile-title {
display:none;
Thank you. Tile Master is very close to where I need to be.
I will need to figure out how to have a method of combing attribute text and icons.
