Hi all. I am using C7 and recently bought a current/ power sensor with one clamp that works with ZigBee.
I successfully connect it to hub by @kkossev 's tuya power meter driver. I can read the current, voltage, frequency etc.
I connect the clamp to my ac to see what is it's state, on or off.
When there is current more than x.xx amp. AC is working ( there must be a stand by current).
The thing is there no rule on the Hubitat that using current or in the driver which shows or triggers when there is an amount of current.
Someone please help?
Update:
I succeed with "rule machine".
Glad you were able to find what you needed. Could you share a link to the device?
Sure. Here is the link https://a.aliexpress.com/_oFazhm2
Now waiting for zigbee ir remote controller.
Hopefully I will control the AC / HVAC unit via Hubitat
If this is the Tuya IR controller, there is no driver for Hubitat ...
So I have a big problem now...
This post had some info, but based on using the Tuya app and alexa.
