Upgraded to hub version 2.2.8.156. Now when I try to highlight a line to copy. The whole window moves. Making it impossible to copy. Anyone else seeing this?
Yes.
Workaround: Click the first line you want. Hold Shift and left click the last line you want. The text should now be highlighted, and you can copy it.
That is the workaround I've been using but, why can't the CSS window work like a regular window with normal mouse functions? It used to work that way.
