Are there any apps that use Keen vents to balance room temperatures?
On ST I have a custom WebCore piston that uses my Ecobee sensor temps, the HVAC run status, and HVAC mode to adjust my Keen vent positions to balance temperature in a few rooms.
I'm hoping I can replicate this in RM, but we'll see...
It uses a number of variables and math to determine things such as which room is hottest when AC is running / which room is coldest when heat is running to determine which vent should be 100% open and which one gets throttled. I just don't see how I will replicate that in RM, but I haven't sat down and started working on it yet - I might be able to do it with a bunch of rules combined if I break it into pieces.
Before I start on that complicated conversion, I thought I would ask if there are any other alternatives.
