Continuous Zigbee disconnection , Bad News
I shot all my cartridges
i don't know what else to do
If they are always disconnecting then you have nothing to lose by resetting them? Also you might also try deleting the plug from HE and set them up like a new device, instead of re-pairing them.
I have deleted and tryed to connect as a new one, the result was the same.
I dont know what is the resetting procedure for this plug i check in google.
Thanks for the suggestion.
which driver are you using? Also maybe you can do a soft reset of the hub Soft Reset - Hubitat Documentation and restore a backup from before the issues started.
The only reset procedure i found is to keep pushed the button for 10s , so i have did it 100 times
Generic zigbee outlet
I will try the soft reset during the weekend
Try this? Ledvance smart+ plug, model 4058075208322?
Nue ZigBee switch
ill try
But the problem is always find it, at the moment i cant find the device using "Discover Device"
What Is the correct driver for It?
For the repeater, you can use the stock Ikea Zigbee repeater driver.
For the Contact sensor, you can use the following:
