Ledvance smart+ plug, model 4058075208322
For anyone using the Ledvance Smart+ plug / outlet with a part number of 4058075208322 (UK model), it works with driver "Nue ZigBee switch".
FYI, here's a link to the specific model I'm referring to;
https://smile.amazon.co.uk/dp/B07V1TL9NH/ref=cm_sw_r_cp_apa_fabc_M0BZDVE73P81BDYH6S29?_encoding=UTF8&psc=1
I have been using the continental version, with the schuko plug.
In my case I have used the Generic Zigbee Outlet driver with no issues.
I tried that first, but got no response from outlet. Might be a difference in part numbers (maybe this is a new device?)
How is your switch working Daren?
i've just got my Hubitat this week so i'm still on a learning curve, i just see a post on amazon uk which i assume is you with a link to the driver above so i just ordered one.
Tony
Working perfectly. Just added a second one as the price is good for a ZigBee outlet
Thanks, i can comfirm that this does work with the generic zigbee outlet driver.
Does yours report watt usage?
Tony
No, no reporting. I don't think this outlet supports it, but I never really checked as it's not important for my purposes.
Did you find out if the device can report watt usage
/Jan
No, there is no reporting on mine
