Success! I got it to work after the hub update. I should note for others that it was not an immediate fix following the hub update though. At first it still did not report the contact state so I tried excluding the device and re-including it. That did not work either. What had to be done was to cycle through the contact states of the triggering device and trigger both open and closed. Once I did that it started reporting again.
Just setup a new Mimo2+ and I’m seeing the same issue. Don’t know if this problem is driver specific but my MIMOLite is still working. The Mimo2+ doesn’t report the contact states.
I am showing similar contact state issues with the Dome Mouser. Was not updating status even when it was triggering...could toggle it open and close with the power switch to get it to report after some fiddling but seems less reliable than before the updates. Could be coincidence? Is this something that needs to be looked at @mike.maxwell in the same vein as the mimolite and aeotec doorbell?
I just turned on the debug logging which showed in the logs and opened / closed one of the contacts. Nothing else showed in the logs so no indication in the contact change.
The driver is assigned as a Fortrezz MIMO2+ but it still does not report the contact input states. I can see the onboard contact indicator LEDs go on and off as I open and close the contacts.
I can not control the relays manually from the child devices or effect any change by 'jumping' the contacts to the relays. There is no indication that the 'jumping' is even taking effect.
Not sure where to go from here. I also contacted Fortrez support and they of course say that if its registering the contact status on the device that it is unlikely there is a hardware issue. I'm also now a week outside my return window which is why I was a bit frustrated and wanted to get some follow up on this issue. I'm a bit loath to fork over another $80 for this device.
