Hi,
I’m hopeful to get some pointers here, or advice that makes the penny drop, please.
I have a system that I need to get working, reliably and in a manner that a number of people with varying skill can work. I’m currently doing it all somewhat manually!
Setup:
A building with 8 individual rooms, and some communal areas.
Occasionally it’s fully occupied, 8 families. Otherwise irregular occupancy. Significant vacant periods. Often only one room is occupied, so only small area needs heating.
Equipment:
Two new gas boilers, one for heating, one for hot water.
Two large water tanks.
Three rooms have wet UFH.
Five rooms have radiators.
Communal areas have wet UFH.
The entry hall has a radiator.
There are 10 Heatmiser NeoStats. (! I know, but they are all necessary…)
One each to control the two water tanks.
One in each of 3 rooms
Three to control 3 zones in communal areas.
One to control overall UFH on/off (i.e. open flow to the manifolds and I think fire the boiler)
One to control flow to the radiators (and I think fire the boiler).
There are Zigbee TRVs on each radiator. (Moes BRT-100)
There are about 6 Zigbee temperature sensors around.
There are some Zigbee motion sensors too.
There are two other systems, alarm and access control, with no voltage outputs to indicate events/states.
And one Hubitat!
Still with me?
I know it looks like a bit of a mishmash, but no one involved with the installation or build could come up with a unifying solution. The plumbers/builders would have put in mechanical time clocks given a free reign. The underfloor heating people specified Heatmiser.
The builders did, in fact, put in a totally dumb controller for the boilers. This gave us zero remote access or integration. This was replaced with more Heatmiser stuff, as at least this gave us the option to control remotely, and it was more kit from a manufacturer that was already there, rather than yet another platform.
All the other “professionals” maintained that it was impossible to have the radiators in rooms and the Heatmiser stuff work as part of the same system.
My limited experience of Hubitat was the best bet for tying it all together. And I have some anxiety that I’ve bitten off more than I can chew.
The requirements make it hard for any off-the-shelf kit to handle. Radiators and UFH. Often only one of two water tanks is required, but occasionally two.
Needs:
Highest priority is:
Any one room can be heated on its own. Any one temperature sensor, be it a Heatmiser Neostat, a TRV, or a temperature sensor, can call for heat, which turns the heat boiler on and sends flow to the area which called for heat. (This is also critical for frost protection)
Wants:
Some sort of control in each radiator room, so that people can see what it’s set to, and turn it up or down. Ideally something like the Neostats! On a wall, easy to operate. I have bought a Moes Zigbee thermostat to try out. I’ve not got very far with it, however. I’ve read some threads on how it’s not easy to have something like that operate just as an interface, essentially.
Progress so far:
I’ve installed at the Heatmiser Neostat app, and basically got it going. It is terrible.
Tuya wall thermostat driver to run the TRVs. And the Moes thermostat. (Thanks kkossev.)
I’ve installed Thermostat Controller 2.0, and it’s the most confusing and frustrating thing I’ve encountered in ages. I’ve lost hours of life to it. Perhaps by now the rest of the task would seem easy if that one aspect wasn’t still shrouded in mystery.
Once this is basically working, then we could layer on other things, all the clever automations I’ve told the others about. Presence detectors to turn areas down if not occupied, set everything to frost protection when the security alarm is armed, etc. But until the basics work, we can’t move forwards!
I would consider using other TRVs, as they are straightforward to replace, if it would give me an easy life. Other interfaces for the radiator rooms too could be purchased.
I think we’re stuck with the Heatmiser stuff: it’s too hardwired in, too much of it. It would cost thousands of pounds to replace.
Are there any setups I could copy/look to for inspiration? Any guidance? Is there another solution I should be considering? Does anyone want a gig helping to get it work?
I know it’s a bit of a handful. I’ve been tinkering with Hubitat for years, and had reasonable success. I’ve hit a roadblock here. Help, please!
