Compatibility with ZigBee 3.0 Pro+ 3 in 1 RGBCCT/RGBW/RGB LED Strip Light Controller model LT-GL-C-202P
Fairly new to this as my first device added to the C8-Pro. Found the device and it was added. But the response time is almost non existent after turning it on one or twice. So far it doesn't respond.
Any help will be appreciated in assisting in getting my skills up to par with the new system.
You can try this workaround until the next HE platform major update is released. It is currently in BETA testing.
Do beta testers have the option to provide feedback? I'm considering but wondered if I should grab a backup hub in case during betas or private river building takes a longer learning curve than expected.
I suppose one of the major goals of beta testing is to provide feedback to the to HE devs... For me, it is easy, as I have a spare hub that I use for testing and developments, But it is also HE standard feature to revert to previous platform versions, if anything goes wrong.
Having a backup hub is always a good idea.
