CoCoHue is not updating devices status after update
Hi. I updated today hub and CoCoHue driver. I have c8-pro on 2.4.0.151.
Since this bulbs and motion sensors are not updating their status (on/off) at Hubitat.
How may I fix it?
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
Please check that all app and driver code files were updated if you did it manually, or try a repair from HPM. Also, check logs for any errors. It is hard to troubleshoot without knowing anything else, so sharing as much as you can would help.
Ok, I found option "refresh even stream" at coco device. It helped.
That is not the name of any specific command or preference, though there are many that share bits and pieces of the words in that phrase. Nor is there any one "coco device." CoCoHue is a collection of drivers (which are used to create devices) and a parent app.
I am glad you have found a solution. If you have more problems in features, providing specific information will be helpful, including the particular app or driver, the exact phrasing you see if you're referring to something in the interface, as well as entries from "Logs" as requested above. Good luck!
You may also wish to consider using the built-in Hue integration, particularly if you are on (at least) platform 2.4.0, as it has a similar feature set and frees you from needing to install (or update) additional apps and drivers on your hub.
