Cheap uk Zigbee switch for £10
I actually ordered these from the seller, way back in December, but unfortunately they never arrived. I did get a refund however. But I still want the drivers :wink:
You need a permenant live
You could always put a cover over the switch so it doesn’t get turned off.
Andy
Driver in this post
Andy
Whats the default PowerOn state on these ?
Just wonder if i will be able to turn it back on from the wall switch when its remotely set to Off .
I have never specifically tried but I think it's default on
im a total noob, ive got a xiaomi door contact that ive paired but failed to get to work, and also a trv head Danfoss, if you could be any help that would be appreciated
I Use Zigbee on off switch written by cobra..
And no, I have not found a decent UK light switch, they all seem to be wireless. Let me know if you have any luck!
Just ordered a couple of these, hopefully I can use them and not have to buy 10 bulbs...I have spot lights in some rooms and didn’t fancy the expense
I've just got a few of these to try and they seem very good so far. I've also managed to modify one so that rather than switching the input voltage to the output terminals, it becomes a "dry contact" relay. IE the output contacts are no longer connected to the 240V at all but just become a normally open pair of contacts that close when the switch is on. See picture for the modification I did.
NB1. You need to cut through the PCB tracks on BOTH sides of the board as the tracks run on both. I found the easiest way in the end, rather than trying to grind through the copper tracks, was just to make a saw cut through the whole board where I've shown the red line.
NB2 This would obviously void any warranty and messing with 240V electrics is dangerous etc etc so I am not recommending anyone try this themselves. Just posting what I have done for information.
Out of interest, did yours work out-of-the-box with one of the built in generic drivers?
Or did you have to load a custom driver?
Yes, they work fine with both Generic Switch and Generic Outlet Zigbee drivers.
Hi guys, I have two of these since April, when I was looking for a cheap Zigbee alternative to the Sonoffs. I can confirm they work quite well with Smartthings and Hubitat, using the native generic drivers.
Hi
As I have understood, you because of others stupidity not made this available any longer to the public. Is there a way to get it now?
hermod,
yes, its still available. Loads of sellers have it in the UK. I have just bought a further 3. Where in the world are you?
The driver will be available on my members website when it opens
But you may find one of the inbuilt drivers work
Andy
Ok. I will try the Generic driver.
I have already bought them - I was looking for the driver that @Cobra had made
This returns Error 404 Not Found for me. Do you have a new link? I am trying to get switching functionality from a Tradfri Signal Repeater if possible.
Andy
Could you send a link to the device please.
